    Array of unique points?
    10 Posts 4 Posters 820 Views 4 Watching
      When you have an array of arbitrary points - and you want to ensure that array only contains unique points, how do you filter them out?
      points.uniq! doesn't seem to work.
      Example:
      ` point1 = Geom::Point3d.new 1,1,1
      Point3d(1, 1, 1)
      point2 = Geom::Point3d.new 10,10,10
      Point3d(10, 10, 10)
      point3 = Geom::Point3d.new 10,10,10
      Point3d(10, 10, 10)
      a = [point1, point2, point3]
      [Point3d(1, 1, 1), Point3d(10, 10, 10), Point3d(10, 10, 10)]
      a.uniq
      [Point3d(1, 1, 1), Point3d(10, 10, 10), Point3d(10, 10, 10)]`
      • Chris FullmerC Offline
        Any chance you are getting the points from an array of vertices? Vertices will respond to the uniq(!) methods. I can't think of any time that I actually sorted by Point3d objects. And I tihnk it was because I found it easier to use vertices, which has always worked out ok for what I was writing.
        Chris
        All my Plugins I've written
          No, not vertices. computed intersections.
            atm I got this code:
            def self.uniq_points(points)
              old_points = points.clone
              new_points = []
              until old_points.empty?
                point = old_points.shift
                point_exists = false
                new_points.each { |p|
                  if p == point
                    point_exists = true
                    break
                new_points << point unless point_exists
              return new_points
            but I was wondering if there was a better method....
              Yeah, as I was thinking - each Point3d object is its own object, and therefore different, even though they might share the same coordinates in space.
              You need to compare them as strings I suppose, since I see no quicker comparison method(?). Try this line:
              ` a = [point1.inspect, point2.inspect, point3.inspect]
              a.uniq`
              That should work, I don't know how slow it will be if its over zillions of points though,
              Chris
                no, not string. you can compare two points - point1 == point2 if return true if they are the same point, withing some tolerance SU has set. But it seems that array.uniq doesn't do this type of comparison...
                  Point3d's will be uniq!'d if they have the same ID BUT NOT if they have just the same XYZ values [they aren't really equal are they?], but we can write a simple def to sort it out...
                  def unique(pointsIN = [])
                    return pointsIN if pointsIN.to_a[0].class != Geom;;Point3d
                    # we'll only process an array of Point3d's ?
                    points_a = []; pointsIN.to_a.compact.each{|p| points_a << p.to_a}; pointsa.uniq!
                    # we compact to remove any 'nil' entries ?
                    pointsOUT = []; points_a.each{|p| pointsOUT << Geom.Point3d.new(p.x, p.y, p.z)}
                    return pointsOUT
                  end#def
                  # Assuming a list [array] of Point3d's that might contain duplicates called 'points' then...
                  points = unique points
                  # will give us a list [array] of unique Point3d's called 'points'...
                    Alternatively, following TT's point1 == point2 idea
                      pointsOUT=[]
                      pointsIN.to_a.each{|p|
                        duplicated = false
                        pointsOUT.each{|po|
                          if po == p
                            duplicated = true
                            break
                          end#if
                        pointsOUT << p if not duplicated
                      return pointsOUT
                    end#def
                    points = points unique
                    Which keeps the Point3d's IDs unchanged...
                      MartinRinehart
                      Have you tried just adding them to a set?
                      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
                        I was pretty sure I'd tried that! 😲 But clearly I haven't!
                        Point3d(1, 1, 1)
                        Point3d(10, 10, 10)
                        Point3d(10, 10, 10)
                        s = Set.new
                        #Set:0xbd7da68
                        s.insert(point1)
                        #Set:0xbd7da68
                        s.insert(point2)
                        #Set:0xbd7da68
                        s.insert(point3)
                        #Set:0xbd7da68
                        s.to_a
                        [Point3d(1, 1, 1), Point3d(10, 10, 10)]`
                        Very interesting that it evaluates differently. It compares the values, not the objects. 👍
                        Exactly the kind of solution I was hoping for.
