    HLR.parent BUG SPLAT!
    6 Posts 4 Posters 2.3k Views 4 Watching
    • Dan RathbunD
      Dan Rathbun
      The HLR.parent method does not have error handling to trap when the object is not yet attached to a collection or other object.
      If .parent is called on any HLR class object before attachment, a BUG SPLAT! results.
      The method should either return nil when it has no parent, or raise a proper Exception. In both cases the $! error message should be set to some meaningful string, ie: "Nesting Error. No parent object..." (or similar.)
      Platform: Win32
      Sketchup: 7.1.6087
      --report--
      At Ruby Console:
      var=Sketchup::HLR.new
      var.parent
      --> BUG SPLAT!
      I have no idea what an HLR entity subclass is used for! It inherits all the Entity baseclass methods, and adds 2 of it's own, .calculate and .num_faces
      The Sketchup::HLR class is undocumented in the API.
      I'm not here much anymore.
      • tbdT
        tbd
        same problem on Mac as well. let's see what HLR stands for ? Hyper Lazy Render ? πŸ˜„
        SketchUp Ruby Consultant | Podium 1.x developer
        http://plugins.ro
        • AndrewSA
          AndrewS
          I've brought this to the attention of Simone, our Ruby QA expert.
          Andrew
          Andrew S.
          SketchUp Release Engineer
          • thomthomT
            When do you ever get an HLS class anyway?
            • Dan RathbunD
              Dan Rathbun
              You can make one using: var = Sketchup::HLR.new
              But as I had said in the API forum:this post
              @dan rathbun said:
              The classSketchup::HLR is undocumented in the API.
              It's an Entity subclass.
              It inherits all the Entity baseclass methods, and adds 2 of it's own:
              • .calculate* .num_faces
              If you create a HLR object at the console, and call .parent (when it has no parent) a BUG SPLAT! results. See post: (link to this Bug Reports thread.)
              What is this class HLR used for? (.. as there is no .add_HLR method for the Entities collection object.)
              The HLR question remains unanswered...
              _
              • Dan RathbunD
                Dan Rathbun
                ... let's see what HLR stands for? Hyper Lazy Render ? πŸ˜„
                Apparently it stands for Hidden Line Renderer (or similar.)
                If Sketchup::HLR is a private internal class, meant only to be used by Sketchup itself, it's constructor method should be made private (and/or renamed.) In addition, the API should probably tell us not to mess with it.
