    HLR.parent BUG SPLAT!
    6 Posts 4 Posters 2.2k Views 4 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      The HLR.parent method does not have error handling to trap when the object is not yet attached to a collection or other object.
      If .parent is called on any HLR class object before attachment, a BUG SPLAT! results.
      The method should either return nil when it has no parent, or raise a proper Exception. In both cases the $! error message should be set to some meaningful string, ie: "Nesting Error. No parent object..." (or similar.)
      Platform: Win32
      Sketchup: 7.1.6087
      --report--
      At Ruby Console:
      var=Sketchup::HLR.new
      var.parent
      --> BUG SPLAT!
      I have no idea what an HLR entity subclass is used for! It inherits all the Entity baseclass methods, and adds 2 of it's own, .calculate and .num_faces
      The Sketchup::HLR class is undocumented in the API.
      I'm not here much anymore.
      • tbdT Offline
        tbd
        same problem on Mac as well. let's see what HLR stands for ? Hyper Lazy Render ? πŸ˜„
        http://plugins.ro
        • AndrewSA Offline
          AndrewS
          I've brought this to the attention of Simone, our Ruby QA expert.
          Andrew
          Andrew S.
          SketchUp Release Engineer
            When do you ever get an HLS class anyway?
              Dan Rathbun
              You can make one using: var = Sketchup::HLR.new
              But as I had said in the API forum:this post
              @dan rathbun said:
              The classSketchup::HLR is undocumented in the API.
              It's an Entity subclass.
              It inherits all the Entity baseclass methods, and adds 2 of it's own:
              • .calculate* .num_faces
              If you create a HLR object at the console, and call .parent (when it has no parent) a BUG SPLAT! results. See post: (link to this Bug Reports thread.)
              What is this class HLR used for? (.. as there is no .add_HLR method for the Entities collection object.)
              The HLR question remains unanswered...
              _
                Dan Rathbun
                ... let's see what HLR stands for? Hyper Lazy Render ? πŸ˜„
                Apparently it stands for Hidden Line Renderer (or similar.)
                If Sketchup::HLR is a private internal class, meant only to be used by Sketchup itself, it's constructor method should be made private (and/or renamed.) In addition, the API should probably tell us not to mess with it.
