    QTVR
    renderpluginsextensions
    6 Posts 5 Posters 1.8k Views 5 Watching
    • A
      abumail
      Dear All,
      I'm trying to make a QTVR using Sketchup and Vray, the quality of th e still images is Ok but after the covertion inn QTVR everything seem ugly, we can se the edge and angle of the cube.
      I used cubicpanoout.rb to set the scenes.
      Any suggestion?
      Thank yuo in advance
      Cheers Giovani
      QTVR
      • GaieusG
        Hi Giovani,
        I don't use V-ray but my guess is that it calculates the light differently for each scene.
        We have a V-ray subforum here - I will move your topic there - maybe someone can help you.
        • thomthomT
          That .mov just flicker for a fraction of a second.
          • A
            alpro
            Try to render as an animation just the irradiance map and save to a file, then rerender your scenes, loading the irradiance map that you saved, also make sure that vignetting is unchecked.
            Mike
            • M
              madhav
              I recently learned making QTVR. If the still images does not have lighting (greyishness) differences than its ought to be problem with the image stitching and QTVR conversion software you're using. I'm using free version of a software called PANO2QTVR. It allows you to create movies our of equirectangular, cylindrical and cubic images.
              Here is one quick Bath MOV made using above software.
              Quick Bath QTVR
              • A
                abumail
                [quote="alpro"]Try to render as an animation just the irradiance map and save to a file, then rerender your scenes, loading the irradiance map that you saved, also make sure that vignetting is unchecked.
                i gonna try without vignetting
                giovanni
