VfSU Animation??
Hi all, I'm in the process of learning animations and what not. Here at our company we want to put together fly-throughs of our projects for the clients to see and also to put on our website. Can someone lay down in simple steps the process one needs to do to create a video?
Under the output menu in the vray options there is an animation box, which I have checked, but when I render it just does all the frames and then ends up with nothing. Do I need to save all the renders and then combine them into a video? If so, how would I do that?
Please give me some insight!!!
Thanks,
Steve
I emailed ASGvis about this. They said ............. .........
It is possible to do what is called a "fly-through" animation using SketchUp (and therefore V-Ray) in which only the camera moves. This is not a supported function of V-Ray but something that SketchUp does that we can enhance using our render engine. You can find tons of information about animation on our free forums. Here is a link to just one of the many postings about this:
http://forum.asgvis.com/index.php?topic=4324.0However I am having trouble accessing the ASGvis site! So Ihope it can help. Please let me know.
Guy
Guy
Thanks Guy for the insight. I will have to take a look at this. I am new to rendering fly-through's and stuff and i will probably end up doing them in 3DS Max, but I just wanted to see if there was any easy way to accomplish this with sketchUp, because I love that you don't have to switch from program to program.
I rendered two scenes as an "animation" from the vRay options and saved the jpg's. I tried then combining and creating them into a video in Sony Vegas but the thing is, is that it isn't arranging the jpgs as 30frames/sec. its doing like 1 frame every 4 seconds and I have no idea how to tell it to do it 30/sec.
Hope someone has a simple solution,
Thanks again!
Steve
Register LoginAdvertisement
