    How replace material & remove material from edge ?
    5 Posts 2 Posters 1.9k Views 2 Watching
      Daryan
      Hi all,
      • How can i remove all material from all edge of the modele (edge only, not face) ? Is there a plugin for that ?
      • How can i replace a material by an another in all the modele ? Is there a plugin for that ? Right clic, select, select all face with same material doesn't work beacause there is a lot of group and component.
      Thanks by advance for your help.
        Switch to Wire-frame Mode so that only Edges are now visible,
        Select the Edges to be changed,
        Set the current Material to <Default> in Browser,
        Paint Selected Edges with it.
        To check their Material - use Entity Info -
        [Note that you can also change their Material in this dialog too]...
          Daryan
          Realy good idea, i never think to use the Wire-frame mode. But i have a lot of group and component (more than a thousand), and i want to cleanup the Edge material, because they prevent me to purge unused material.
            This http://forums.sketchucation.com/viewtopic.php?p=96863#p96863 will change or remove materials from selected items too...
              Daryan
              Your plugin is perfect, thanks a lot !
              [Topic resolved]
                http://forums.sketchucation.com/viewtopic.php?f=323&t=17587&p=140672&hilit=[Plugin]#p140672
                (the plugin doesn't work for component but it's a good start).
                (the plugin work perfectly).
