    Importing and placing components
    7 Posts 4 Posters 529 Views 4 Watching
    • RichMorinR
      RichMorin
      I'm writing a Ruby script that (using AppleScript) causes SU to start up, open a file containing a "wall" (10' x 10' x 1' box), and import a component file. This all works, except that I don't know how to place the component against the wall.
      Clues?
      -r
      • TIGT
        Perhaps get it to set a flag [$xxx] so you know that it's done something.
        Then when your model opens it finds the component by its name [defn] and then uses - for example:
        model=Sketchup.active_model
        defn=model.definitions[your_components_name]
        tr=Geom;;Transformation.new(your_required_point_on _the _wall)
        model.active_entities.add_instance(defn,tr)
        • RichMorinR
          RichMorin
          Thanks, TIG! That almost works.
          If I just run the script, the component never shows up. However, if I click on the border of the main SU window (using the mouse), the component appears in the specified location. So, what do I have to do to mechanize the mouse click?
          -r
          • RichMorinR
            RichMorin
            Hmmm. I just tried a sleazy hack which seems to work:
                model.active_entities.add_instance(defn, tran)
                Sketchup.send_action('selectSelectionTool;')
            Selecting the Selection Tool seems to "wake up" SU, causing it to place and display the component without any user action.
            -r
            • scottliningerS
              scottlininger
              Not sure if this would do the same, but you might try view.refresh.
              http://code.google.com/apis/sketchup/docs/ourdoc/view.html#refresh
              Cheers,
              • Scott Lininger
                SketchUp Software Engineer
                Have you visited the Ruby API Docs?
              • thomthomT
                Cheers,
                That isn't meant to be used within Tools? Thought most view methods where.
                (might also be worth noting that it's 7.1 - so you'd still need another workaround for older versions - if this method if working.)
                • TIGT
                  You have exited your Tool so the View refreshes...
                  selectSelectionTool changes to that tool...
                  No hack... No magic involved... β˜€
