    Importing and placing components
    7 Posts 4 Posters 389 Views 4 Watching
    • RichMorinR Offline
      RichMorin
      I'm writing a Ruby script that (using AppleScript) causes SU to start up, open a file containing a "wall" (10' x 10' x 1' box), and import a component file. This all works, except that I don't know how to place the component against the wall.
      Clues?
      -r
        Perhaps get it to set a flag [$xxx] so you know that it's done something.
        Then when your model opens it finds the component by its name [defn] and then uses - for example:
        model=Sketchup.active_model
        defn=model.definitions[your_components_name]
        tr=Geom;;Transformation.new(your_required_point_on _the _wall)
        model.active_entities.add_instance(defn,tr)
          RichMorin
          Thanks, TIG! That almost works.
          If I just run the script, the component never shows up. However, if I click on the border of the main SU window (using the mouse), the component appears in the specified location. So, what do I have to do to mechanize the mouse click?
          -r
            RichMorin
            Hmmm. I just tried a sleazy hack which seems to work:
                model.active_entities.add_instance(defn, tran)
                Sketchup.send_action('selectSelectionTool;')
            Selecting the Selection Tool seems to "wake up" SU, causing it to place and display the component without any user action.
            -r
            • scottliningerS Offline
              scottlininger
              Not sure if this would do the same, but you might try view.refresh.
              http://code.google.com/apis/sketchup/docs/ourdoc/view.html#refresh
              Cheers,
              • Scott Lininger
                SketchUp Software Engineer
                Have you visited the Ruby API Docs?
                Cheers,
                That isn't meant to be used within Tools? Thought most view methods where.
                (might also be worth noting that it's 7.1 - so you'd still need another workaround for older versions - if this method if working.)
                  You have exited your Tool so the View refreshes...
                  selectSelectionTool changes to that tool...
                  No hack... No magic involved... β˜€
