    Problems printing to scale
    2 Posts 2 Posters 440 Views 2 Watching
    • N
      Nstocks
      I have designed a building to the scale of 1:1. When it comes to printing, the image is tiny. I've read various guides but can't even find the scale menu to set up the output scale...
      Thanks for your help
      • cmdC
        cmd
        Nstocks,
        There are 2 ways to print at a specific scale....
        From SketchUp:
        -Set your camera settings to parallel projection and find the view you want to print out.
        -> With this setting ON, your print options menu will now have fields available to you to allow for printing at different scales of your choice.
        From LayOut:
        • Chose your paper size.
        • Embed your model into the paper space and set your embedded model to parallel projection and find the view you want to print out.
          -> Under the SketchUp Model menu, chose your scale from the dropdown menu.
        I hope this helps
        CMD
        • CMD
