Problems printing to scale
I have designed a building to the scale of 1:1. When it comes to printing, the image is tiny. I've read various guides but can't even find the scale menu to set up the output scale...
Thanks for your help
Nstocks,
There are 2 ways to print at a specific scale....
From SketchUp:
-Set your camera settings to parallel projection and find the view you want to print out.
-> With this setting ON, your print options menu will now have fields available to you to allow for printing at different scales of your choice.From LayOut:
- Chose your paper size.
- Embed your model into the paper space and set your embedded model to parallel projection and find the view you want to print out.
-> Under the SketchUp Model menu, chose your scale from the dropdown menu.
I hope this helps
CMD
