    [Plugin] hide all edges
    11 Posts 5 Posters 23.3k Views 5 Watching
    • CadFatherC
      CadFather
      Thanks to Fredo, a script that can hide recursively all the edges inside a group or nested groups\components
      scroll down for the plugin by Fredo:
      http://forums.sketchucation.com/viewtopic.php?f=180&t=24424#p209144
      • juan974J
        juan974
        hello,
        when you are in a component change render mode for "wireframe" then hit ctrl+A to select all (edges only because you are in wireframe mode), then goto edit > hide.
        return to "shaded whit textures" render mode .
        hope it s helps
        juan974 (Réunion island)
        website : http://sketchucation.com/click.php?url=http://www.tarn.us
        • CadFatherC
          CadFather
          thanks Juan, to do that you can also use Thom's selection tools or Didier's selection filters
          ..but my aim is to be able to hide the edges inside all sorts of nested groups/components
          the script mines down all the levels and hides all the edges it finds...fingers crossed
          • soloS
            solo
            Fredo, I wonder if it's possible to have one that will show all edges too (opposite), reason for that is when I need to save an line image for overlay, I need to go into all the groups, components, nested stuff and unhide them.
            http://www.solos-art.com
            • CadFatherC
              CadFather
              Fredo, the script works perfectly and very fast.. Superthanks! ☀
              Pete, isn't the script already doing this with unhide?
              • soloS
                solo
                Cadfather
                The problem I have is with imported geometry, normally Maya and Max models that have lots of embedded groups, you need to go into every group to unhide the edges.
                • CadFatherC
                  CadFather
                  perhaps i don't understand you, but when i hit unhide it does so on all sub groups..
                  • fredo6F
                    fredo6
                    @cadfather said:
                    hi, is there a script that can hide recursively all the edges inside a group or nested groups?
                    Here is a old, undocumented script I wrote a while back.
                    It will Hide, and Unhide, all edges, at all levels of the current selection, or to the whole model if the selection is empty.
                    There are 2 entries in the Plugins menu for these operations
                    [Edit 13 Dec 09, 11:45pm] I made it work on the selection too.
                    Fredo
                    to drop in Plugins Sketchup folder
                    • fredo6F
                      fredo6
                      CadFather,
                      I just make it work on the current selection. If it is empty, then the script considrs the whole active model.
                      The rb file is updated in my post above
                      Fredo
                      • CadFatherC
                        CadFather
                        thanks Fredo, fantastic time saver... 😄
                        • J
                          jonatanr
                          Awesome!
