    DC Bolt Builder
    7 Posts 7 Posters 7.7k Views 7 Watching
    • H
      Howard leslie
      DC Bolt Builder
      See attached
      Release Log:
      V3 2009-12-12 first public release.
      V3 2011-09-10 edits to jpgs / all attachments reloaded / no edit to DC
      Users can enter variables in any units eg millimetres, feet and inches etc
      Bolts can be built to any size.
      Turn Layers On / Off as required eg BoltOrigin, BoltCentreMarks etc
      The Scenes (Pages) shown in the *.skp file eg ISOs / Elevations / Plans etc can be used to help Export out the data to 2D CAD (eg Autocad) if Reqd. (see screen dump).
      Any probs / suggestions / improvements / feedback etc - giz a shout
      Enjoy
      Howard L'
      Keywords: DC Dynamic Component Bolt Bolts Nut Nuts Washer Washers Builder
      Bolt Builder Dynamic Component Dialog Box
      Bolt Builder Data Exported out for use in AutoCad
      DC Bolt Builder
      • R
        remus
        Wicked component πŸ‘
        • utilerU
          utiler
          That's nuts! [Pardon the pun....]
          Well done Howard and thank you kindly for sharing....
          Just Curious...
          • G
            Gridbeam Solutions
            Newbie here -- Bolt Builder is a GREAT concept, but I'm having some problems with it (SketchUp 8 free; Mac).
            I did figure out that for US Standard bolts, I need to change the file's measurements to Fractional in order to input measurements in inches.
            However, if I enter a material thickness of 3", BB lists the shaft length as 5.071" -- NOT the correct 3.5".
            Also, if I enter a shaft diameter of, say, 5/16", BB converts that to 5" (!). Yes, 5 INCHES wide. If I enter the number as a decimal (e.g. .25" instead of 1/4"), BB acts correctly.
            BB also specifies a very narrow washer, whereas my application requires wider washers. Yes I can go in and change the washers manually... but it would be nice to have the option to type in a value in BB and override the calculated default.
            Hopefully I'll get to be enough of a SketchUp expert at some point to build on your excellent work and make dynamic component Bolt Builders for more types of hardware. Thanks for posting this!
            • M
              mlyall
              Great DC, thanks for sharing.
              • J
                jumpjack
                Can't threads be created too this way?!?
                • J
                  Jspro
                  Does this program create the threads?
