    Why import not have dwg
    11 Posts 9 Posters 2.3k Views 9 Watching
      sheir
      Hi guys,
      Why my skecthup pro 7 , not have dwg in import list??
      because I would like to import autocad file
        Hi Sheir,
        SU 7 Pro should have the dwg import. It was disabled (or rather moved to a plugin) in SU 7.1 Free lately.
        • AndrewSA Offline
          AndrewS
          @sheir said:
          Hi guys,
          If you are running SketchUp Pro 7.1 without a license and your evaluation time has expired, you will revert to free functionality. When that happens, you will not be able to use the DWG importer unless you use the DWG/DXF importer installer from the link that Gaieus provided.
          Andrew
          Andrew S.
          SketchUp Release Engineer
            sheir
            Thanks guys for your replied
            But DWG/DXF import plugin for SketchUp 7.1 (Free) for limited time.
            Are you knew any link free without limited time??
              remus
              Its only the download thats available for a limited time, so theres nothing stopping you from downloading it and keeping a copy for yourself.
                sheir
                Thanks remus,
                I have free sketchup 7.1, not the pro. one,There are way to have link for it.
                Because that one in sketchup website not free for 7.1
                Have a nice day
                • sketch3d.deS Offline
                  sketch3d.de
                  DXF/DWG Import Plug-in f. SU 7.1
                  Windows (MSI)
                  Mac OS X (DMG)
                  further Info
                  hth,
                  Norbert
                  • BepB Offline
                    Bep
                    Hi Sheir,
                    Use Doublecad to import / export http://try.doublecad.com
                    Bep
                    "History is written by the winners"
                      jehany
                      WHY the import DWG/DXF is not available in SUv8-Pro (OSX) anymore... 😞
                        It is still available on the SU8 pro. It appears in the Import file Format list second after SKP. I made this screen shot a few minutes ago.
                        http://farm6.static.flickr.com/5130/5206031597_84363037d0.jpg
                        • AnssiA Offline
                          Anssi
                          I don't know much about Mac OSX, but it seems that quite many people have problems with the importers not showing up in SU Pro under OS X. The recommended solutions range from deleting the preferences file and repairing file permissions to re-downloading and re-installing SU.
                          Anssi
