Why import not have dwg
Hi guys,
Why my skecthup pro 7 , not have dwg in import list??
because I would like to import autocad file
Hi Sheir,
SU 7 Pro should have the dwg import. It was disabled (or rather moved to a plugin) in SU 7.1 Free lately.
@sheir said:
Hi guys,
If you are running SketchUp Pro 7.1 without a license and your evaluation time has expired, you will revert to free functionality. When that happens, you will not be able to use the DWG importer unless you use the DWG/DXF importer installer from the link that Gaieus provided.
Andrew
Thanks guys for your replied
But DWG/DXF import plugin for SketchUp 7.1 (Free) for limited time.
Are you knew any link free without limited time??
Its only the download thats available for a limited time, so theres nothing stopping you from downloading it and keeping a copy for yourself.
Thanks remus,
I have free sketchup 7.1, not the pro. one,There are way to have link for it.
Because that one in sketchup website not free for 7.1Have a nice day
WHY the import DWG/DXF is not available in SUv8-Pro (OSX) anymore...
It is still available on the SU8 pro. It appears in the Import file Format list second after SKP. I made this screen shot a few minutes ago.
I don't know much about Mac OSX, but it seems that quite many people have problems with the importers not showing up in SU Pro under OS X. The recommended solutions range from deleting the preferences file and repairing file permissions to re-downloading and re-installing SU.
Anssi
