    Add attributes to a face???
    13 Posts 5 Posters 1.1k Views 5 Watching
      Mcdull
      I have to do some analytical work.As i select an entity,such as a face, i want to add some attributes to it through UI.inputbox. then if i select this face, it can show the attibutes .i don't konw this way is workable.how to carried out it and where will the attributes be saved?
      thank u~please give me some advice.
        You can add attributes to any Entity. The attributes are stored with the face, so if you delete the face it disappears. To retrieve the attribute again you use get_attribute on that face.
          Mcdull
          how to realize this?
          if i select a face and i want to set an attribute "wall" to the face.
          thank u~
            To set it
            face=model.selection[0]
            face.set_attibute("McDullAttribute","Wall",true)
            ### this gives the face your-attribute called Wall that is true
            To get it
            is_wall=face.get_attibute("McDullAttribute","Wall")
            if is_wall
              puts "This face is a Wall"
            else
              puts "This face is NOT a Wall"
            end#if
            You can work out how to set/get the attributes of any entity like this...
              Mcdull
              thank u very much.as i use this method,it appears a error message:
              Error; #<NoMethodError; d;\test.rb;3; undefined method `set_attibute' for #<Sketchup;;Face;0x5fa96a8>>
              i check the sketchup ruby api document.face has not the set_attibute, just the entity has it.
              so do i need to do it like this:
              face = entities.add_face pts
               entity1 = entities[1]
               status = entity1.set_attribute("McDullAttribute","Wall",true)
              but the face has been exist before, i should not use
              ,but use select method
                Sorry about the typo for attibute read attribute 😳
                  Code; Select all
                  The Face class extends the Entity class. So a Face class has all the methods of the Entity class.
                      face = entities.add_face(pts)
                      status = face.set_attribute("McDullAttribute","Wall",true)
                  In the API, for each class you see which class it extends (if any)
                  Example: http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html
                  Notice that right before the list of methods it says "Parent: Drawingelement".
                  And you also got this diagram you can use as a reference to see how the classes are related: http://code.google.com/intl/nb/apis/sketchup/docs/diagram.html
                  Doing this:
                  Gives you no guaranty that you get the face. You could be getting any random entity that way.
                    Mcdull
                    I'm a newer to use sketchup ruby api and i am so careless to find the little mistake.
                    thank u very much.u are so kind ~
                      Mcdull
                      i got it,i know that Entity is the parent class,but there is a spelling mistake and i am too careless to find it. thank u very much~
                        baldaman
                        Dear jewellers,
                        your discussion give me an idea...
                        If it is possible to define attributes for entities like faces, what about using this method to create an area reporter with the area of each face embeded in an attribute?
                        It would be wonderfull if the area of the face (or collection of faces) could be updated if the geometry is changed... πŸ˜„
                          @baldaman said:
                          Dear jewellers,
                          I have something like that in the workings already.
                          • Chris FullmerC Offline
                            I'm amazed that you keep coming back to the observer's Thom πŸ˜„ They have caused you so much pain already.
                            All my Plugins I've written
                              well... that's the part I haven't done yet. there is an issue with the area calculation SU does when you have skewed groups/components. haven't gotten to the part of adding the observers yet. But I dread it. I've yet not dared to go back to DoubleCut. 😞
