    Default Context Menu Customisation
    6 Posts 3 Posters 613 Views 3 Watching
    • S
      SYD_UK
      Is it possible to modify (add to) the default main context menu (upon right click). It would be usful to have some basic edit commands selectable from this after a right click is invoked, instead of having to select a toolbar for instance.
      • R
        remus
        i think its possible through ruby (and if it is it certainly wouldnt be very hard.) I havent done it myself though, so i'll wait for someone who knows what theyre doing to explain the process.
        • TIGT
          Many tools are context specific and only use that menu to run from.
          For a tour de force of adding commands see my [old] ContextMenuMenus.rb which adds all [now=most?] of the available send action tools to the context menu in sub-menus... it's attached...ContextMenuMenus.rb
          • S
            SYD_UK
            Thanks TIG, it works great.
            I have abridged the script to display just a shortened Tools
            section on the cascade menu from the context menu directly.
            Incidentally how would you position this new menu item at the
            top of the context menu?
            Kind Regards
            Syd
            • TIGT
              I have abridged the script to display just a shortened Tools section on the cascade menu from the context menu directly.
              Incidentally how would you position this new menu item at the top of the context menu?
              Syd
              You can't place a custom menu above the standard ones, BUT to get it as near as possible to the top of the custom list you can give the rb file a name that loads before the others [they load alphanumerically] - so for example ###myscript.rb will load ahead of any others...
              • S
                SYD_UK
                Thanks TIG
                Syd
