    Any SU render engines that renders distorted textures?
    97 Posts 17 Posters 20.1k Views 17 Watching
    • Al HartA Offline
      Al Hart
      why are these working?
      i was under the impression (and i'm almost positive i read this from whaat) that projected textures won't render properly..
      are these not distorted?
      there's only one texture in the model and no exporting of individual faces happened
      It is quite possible that these images are not actually "distorted". There are four handles which can be used to position textures. (These are explained at the beginning of this thread). Three of them move, stretch, rotate and skew the image. Most normal UV mappings consist of only these four things. Many strange looking mappings are only stretched and skewed. Only the upper right handle "distorts" the image. A distorted image cannot be easily defined by 4 UVQ values at the corners of the face. (Distort is a term we use to mean "even worse then skewed". So many images which seem distorted to us are only stretched and skewed.) (Remember normal UVQ mapping can be used to display most projections of images onto spheres and curved surfaces which we see in most modeling and rendering packages.)
      Instead, SketchUp performs a more complicated mapping of the image, saves an already distorted image for us on the disk, and we can them map the image to the face with default UVQ values.
      Al Hart
      IRender nXt from Render Plus
      • jeff hammondJ Offline
        jeff hammond
        indigo
        indigo
        [i'm pretty sure i project these in the normal sense of projecting a SU texture..
        import file as an image.. line it up with the object.. explode the image.. with , hold the cmmd key (mac) and sample the imported texture.. paint on the object i want the image projected onto]
        [EDIT] nvm about what i thought whaat said.. i was thinking about this thread i read a while ago
        http://www.indigorenderer.com/forum/viewtopic.php?f=17&t=7036
        the dude called it a projected texture but i d/ld the model and it was in fact distorted (as dale said)
        [edit2] well, i dunno.. he did say skewed via projection in there πŸ˜‰
        dotdotdot
        • FrederikF Offline
          Frederik
          Al... I really don't get this or any of your explanations... 😐
          What I can see is that your application is also making the texture unique...
          Your application and also Hypershot does the same as everyone else...
          They just export the texture special for each distorted surface...
          Cheers
          Kim Frederik
            jeff hammond
            yeah Al, i think you're right.
            i tried setting up a texture to be projected onto a large flat plane coming in from a weird angle.. the resulting projection should be distorted but instead, it hits then tiles itself...
            for the attached picture... i projected onto the left surface from the little square in the middle assuming it would give results similar to the square on the right (which is distorted) but it doesn't work out that way..
            dotdotdot
              tomasz
              Thea Exporter deals with the sample well.
              Thea Exporter try
              • FrederikF Offline
                Frederik
                Tomasz - are you sure that the distorted texture isn't being exported as a seperate (unique) texture...?? πŸ˜•
                Cheers
                Kim Frederik
                  tomasz
                  @chris_at_twilight said:
                  As for detecting when textures are distorted... I agree that you will very often see 'z' or 'q' (UVQ) values that are not 1.0, but I think you can get false negatives that way. Meaning, you can have distorted textures where the Q is not any value but 1. (This is speculation only)
                  I have never received false negatives by checking the 1.0 with enough precision. The posted TheaExporter sample uses TextureWriter and UVHelper. They work in tandem. The texture writer will create additional ('virtual' unique) texture only when necessary. Sometimes TW can create just a single 'virtual' unique texture for two faces that are parallel to each-other an share same distorted texture.
                  I have spent many hours to understand how the TW works. There is no point in writing every single face to the TW, because it will take a lot of time. I recognize first if a texture is distorted Q!=1.0.
                  if ((uvq.z.to_f)*100000).round != 100000
                  If it is, it goes to TW, which usually leads to a creation of a unique texture. If it doesn't one have to read the 'handle' returned by the TW. It points to the position of a texture in TW 'stack'.
                  It would be interesting to learn how SU DEVELOPERS use additional Q coordinate to add perspective distortion to a texture. I have done a search and haven't found any other software using this type of projection. I hope Google staff would share the trick with authors of redering engines so a use of TW, which is creating additional textures == materials in a renderer, won't be necessary.
                  I have implemented also a method without UVHelper using uv=[uvq.x/uvq.z,uvq.y/uvq.z], but the key is actually to learn how SU applies the projection. As far as I am aware no rendering software uses UVQ.
                  @frederik said:
                  Tomasz - are you sure that the distorted texture isn't being exported as a seperate *(unique)*texture...?? πŸ˜•
                  The method uses TW which crates 'a second texture'==additional 'Thea material'. I have not found a model so far that gives me wrong projection. Unfortunately the method forces creation of multiple Thea materials.
                  EDIT. I modified Thomas' test model. I have added two additional things - a group with a default mat painted face and a second face with distorted texture which will have same handle in the TextureWriter as the one right bellow.
                  UVMappingTest+.skp
                    Maybe you curved surface is subdivided into so many smaller faces that deviation isn't visually noticeable?
                      Tomasz: When you discover a distorted texture (from the Q value), and use TW to write out a unique material;
                      • What UV values do you send to you renderer?
                      • If the render material has a bumpmap applied to it - how is that handled? Won't you end up with mismatching bump?
                      • FrederikF Offline
                        Frederik
                        Yeah - that's what I thought...
                        This is - again - how everyone else is able to handle it...
                        However, I believe thomthom is trying to find out if this can be handled differently...
                        @thomthom said:
                        Yea, Make Unique generates a new texture and gives the face new UV co-ordinates.
                        What I'm trying to find out though, if there is any renderers that actually handles this. More importantly, I'm interesting in how they handle it.
                        IMHO, I hardly never see distorted textures used and thereby it has never been a great issue, certainly not a dealbreaker...
                        Cheers
                        Kim Frederik
                          tomasz
                          When all textures has been loaded to TW I use:
                          					uvHelper=face.get_UVHelper(true, false, tw)
                          					point_pos=mesh.point_at(p).transform!(trans.inverse) #trans='nested transformation' of the parent
                          #thanks to Stefan Jaensch for figuring out that this trans has to be inverted and applied here
                          					uv=uvHelper.get_front_UVQ(point_pos)
                          I use same UVs. I assume that the bumpmap is the same size as the main texture.
                            where do the p variable come from?
                              tomasz
                              It is an index(starting from 1) of a point in a PolygonMesh. You get the Polygon mesh from a face.mesh #.
                              You probably can get point position in other way.
                                Also, why don't you use uv = mesh.uv_at(p, true)? Appears it would give the same result.
                                  If you use my Probes plugin: http://forums.sketchucation.com/viewtopic.php?f=323&t=21472#p180592
                                  Press Tab to see raw UVQ data
                                  By default it will use UVHelper to get the UV data
                                  Press F2 to make it sample the data from the PolygonMesh
                                  From my testing, the data never differs.
                                  UVHelper seem to be made to sample UV data from a Face.
                                  But if you have a PolygonMesh of the Face, it includes the UV data (provided you asked for that when you used face.mesh).
                                    tomasz
                                    I simply use UVHelper because it seems to be designed to this task. What would be the purpose of it otherwise? πŸ‘Š
                                    I am not so sure if it would give same result for two distorted faces sharing same distorted texture (the last pair in the modified skp test scene).
                                    BTW. I have found that there is some memory leak when using UVHelper, at least those objects are not being dumped well (rubbish collector). In my exporter I stay away from UVHelper as long as I can. I read uv coordinates in all other scenarios using uv_at.
                                      tomasz
                                      Ok. Try this. Just load a face with distorted texture to the TW, then you will see the difference if you will use same TW to get uv from UVHelper.
                                      What you have written is true as long as you use blank TW. It gives coordinates in relation to the original 'picture', but when you load a face to TW then it 'makes it unique inside TW' therefore uvs change.
                                      It looks like this thread would better fit in the new developers section πŸ˜„
                                        Chris_at_Twilight
                                        Really? That's good to know. That's a much faster test.
                                        As far as why some projected textures aren't distorted, I think Al and thomthom are both right, given the respective circumstance. It could be that the texture is not truly 'distorted' as Al suggest; it could be that the level of subdivision is high enough that you just don't see the distortion, like thomthom said.
                                        And Tomasz hit it right on the head as far as using tw and uvhelper; you have to make sure you are using a tw 'loaded' with the face in question, before using it in the uvhelper.
                                        http://www.TwilightRender.com
                                          Use a TextureWriter to get UV data? ❓
                                            tomasz
                                            It is the required parameter: uvHelper=face.get_UVHelper(true, false, **tw**)
                                            • 4 / 5
