    Connecting lines and curves
    2 Posts 2 Posters 362 Views 2 Watching
    • T
      tsaG
      I have a problem with my current project. Is there a way to connect a curve and a line? So that I have a continious line?
      When i use the group or component tool, my CNC-Controlling program just gives out some errors. When I Import it without connecting the lines and curves to one line, the program seperates every line or curve into a different object.
      piickguard.skp
      • massimoM
        massimo Moderator
        Hi tsaG, if you want to weld your lines then I suggest you to try this plugin.
