    Dimensions
    4 Posts 3 Posters 357 Views 3 Watching
    • S
      sketchup_fan
      Guys, how wide are skyscraper floorplates, and parking floorplates?
      Oh, and which is the width of a skyscraper glass? ( glassy skyscraper)
      • numbthumbN
        numbthumb
        Hi there
        I only know that the glass boxes on the Willis Tower in Chicago can bear five tons of weight, and they are about 4 cm thick.
        Comfortably numb...
        • TIGT
          The answer is, "What do you want it to be ?"...
          Seriously though - 'walls' can be 4" to 12" thick, but the glass will usually be double-glazed units 1"-2" (even 3-4") thick depending on their size and exposure...
          The floor-plate depth mainly depends on the client's functional requirements. If natural lighting is important then ~25' it's from a window for a workplace: for views out say ~40' - otherwise it doesn't matter much... You'll want no part of the floor-plate to be more than 100' from an exit and 40-60' from a exit if there is no alternative route separated by 45 degrees. If corner offices are their thing then a serrated plan floor is needed to increase their numbers... The [usually] centralized core[s] containing exit-stairs, elevators, service rooms etc will vary in size depending on the floor-plate area [more area can mean more people, more elevators, more toilets] and the building's height [higher can mean more/bigger elevators, means more core footprint etc] - typically let's guess at 15% of the floor-plate...
          • S
            sketchup_fan
            Thank you very much!
