    FOLLOW MEeeeh!
    3 Posts 3 Posters 416 Views 3 Watching
    • N
      NOHD
      hi guys! im having problems with the follow me tool. I always end up with
      http://images.devr13.multiply.com/image/1/photos/50/500x500/11/Picture-1.png?et=CgC6ePFSv9Ly6c5P7%2BRFwg&nmid=265049377
      http://images.devr13.multiply.com/image/1/photos/50/500x500/12/Picture-2.png?et=Y53EWMyeZU1yHZpUfMGy%2BA&nmid=265049377
      these. and these
      http://images.devr13.multiply.com/image/1/photos/50/500x500/13/1.jpg?et=2oqNvnQujsnieqaSm0sguA&nmid=265049377
      http://images.devr13.multiply.com/image/1/photos/50/500x500/14/3.jpg?et=VNAA2L6ezMjnrHGFwXBo%2Cg&nmid=265049377
      i just need some pointers, why do these things happen?
      • jeff hammondJ
        jeff hammond
        the pieces that you're extruding are longer than the radius you're trying to bend them around.. there's going to be some overlap by trying that..
        dotdotdot
        • D
          d12dozr
          You just need one or two more steps....after using follow-me like you did, then select all > intersect with model(if necessary) > and erase the unwanted geometry. Then use eraser + shift or control to clean up the lines on the surface.
          http://goo.gl/f7ooYh
