    After Remus's Little Problem
    22 Posts 7 Posters 1.7k Views 7 Watching
      Use only three 4s (no other numbers) and any common mathematical symbols to write an equation that equals 55.
      • jeff hammondJ
        jeff hammond
        44 + 4 + 7 ?
        [just weeding out the chance that it might be a trick question πŸ˜‰ ]
        edit- [well, there's definitely a trick to it otherwise it's impossible.]
        dotdotdot
        • EscapeArtistE
          EscapeArtist
          44 + 4 + 7 ?
          I like your equation. Follows the rules and gets the job done. Simple enough for me to understand! πŸ˜„
          • jeff hammondJ
            jeff hammond
            ok then it's probably something like
            "use only 3,4s,and any common......."
            so if 44 counts as another number and i can only use a 3 and a bunch of 4s i'll go with...
            4+4+4+4+4+4+4+4+4+4+4+4+4+4-(4-3) = 55
            dotdotdot
            • P
              pav_3j
              not got it perfect, i'm at 52 so far. it is 5:15 am though...
              (4!)*(sqrt4)+4 = 52
              i'll get there though!
              pav
              Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
              • P
                pav_3j
                getting nearer...
                (4 !) + ((4 * 4) * sqrt(4)) = 56
                pav
                • soloS
                  solo
                  444 divided by 4 minus 44, minus 4, minus 4, minus 4 = 55
                  444/4=111
                  111-44=67
                  67-4=63
                  63-4=59
                  59-4=55.
                  http://www.solos-art.com
                  • jeff hammondJ
                    jeff hammond
                    well if factorals, pi, squared, cubed, decimals etc are allowed then it's possible for sure..
                    4! = 24
                    square root of 4 = 2
                    24- 2 = 22
                    22 divided by .4 = 55
                    that's a bunch of numbers other than 3 fours though..
                    πŸ˜’
                    another one thats close..
                    4pi x 4 + 4 = 54.25
                    dotdotdot
                    • jeff hammondJ
                      jeff hammond
                      (4!)*(sqrt4)+4 = 52
                      pav
                      i did it based off what you have...
                      but..
                      4! minus sqrt4 then divide by .4..
                      dotdotdot
                      • jeff hammondJ
                        jeff hammond
                        but if that's in fact an acceptable solution, i'm willing to argue that .4 is as different from 4 as any other number so
                        (4x4)+39 should count too..
                        once you get into sin,cos,tan, sqrts of sqrts, cbrts, logs etc.. i'm sure there are a bunch of different ways to do it..
                        or 4x + 4 + 4 works good too (where x = 11.75) to me, that's not much different than the other symbols that are used as representations for actual numbers.
                        dotdotdot
                        • jeff hammondJ
                          jeff hammond
                          another one that's close
                          4pi x 4.4 = 55.2
                          dotdotdot
                          • TIGT
                            Jeff is right - with three it's (4!-(sqrt(4))/.4=55 [and with four fours it's (4!/.4)-(sqrt(4)/.4)=55]
                            but without decimal points [where .4 != 4 !!!] this way works 'properly'...
                            (sqrt(sqrt(4)))(sqrt(4!))(sqrt((sqrt(4!))!))=55
                            Now try four fours with symbols that = 27... [no decimal points allowed] a bit more convoluted πŸ˜’
                            • jeff hammondJ
                              jeff hammond
                              @tig said:
                              [where .4 != 4 !!!]
                              is 4!!! a legit way to make a smaller number?
                              to me it looks like the number would get bigger very quickly because i'm looking at it as ((4!)!)!
                              if !! or !!! works differently than that, it opens up some more possibilities
                              edit- ok, i checked it out.. the double factorial uses only numbers with the same odd or even relationship..
                              so 4!! = 42 = 8
                              7!! = 7
                              531
                              etc..
                              but while looking at that, i came across the subfactorial .. !4 = 9 so...
                              (4(4sqrd)) - !4 =55
                              [that's squared not square root]
                              dotdotdot
                              • TIGT
                                @tig said:
                                [where .4 != 4 !!!]
                                You misconstrue me !!! I was making an exclamation, that .4 is not equal to 4 (.4 != 4 !!!): after all .4 is really another way of writing 4/10 ...
                                I deliberately separated the ! and made the exclamation three !!! to be sure, but it still didn't work ! πŸ˜‰
                                As I see it the only legit way to make 55 with three 'proper' fours and all proper symbols is my...
                                • jeff hammondJ
                                  jeff hammond
                                  another using decimals..
                                  4.4/.4!! = 55
                                  (well, that is if .4!! = .08)
                                  dotdotdot
                                  • jeff hammondJ
                                    jeff hammond
                                    haha
                                    ok, i see now.
                                    dotdotdot
                                    • jeff hammondJ
                                      jeff hammond
                                      here's an interesting link (well, sort of.. most of the content is way over my head but.... πŸ˜„ )
                                      trying to represent all numbers 1-12 using only one 4..
                                      http://www.cut-the-knot.org/arithmetic/funny/1_4.shtml
                                      dotdotdot
                                      • david_hD
                                        david_h
                                        I realize I am tuning in late, but wasnt this a CarTalk Puzzler? how to get to the number 55 using only five 4s?
                                        44 + 44/4 = 55.
                                        • jeff hammondJ
                                          jeff hammond
                                          anyone want to take a stab at this weeks puzzler from the same site?
                                          An obscenely wealthy hedge fund manager named Throckmorton Bottomfeeder IV decided to build for himself and his trophy wife, a modest little 40,000 square foot home. It was a stone castle complete with an observation tower at one end that was almost 100 feet high - perfect they thought to spot from afar the first wave of angry and disgruntled investors, the kind with the pitchforks and the torches.
                                          The Bottomfeeders had employed the finest masons in all the land to ensure that their castle was as close to the real thing as possible. As the tower was constructed by a very talented and skilled crew of masons working on the outside, another even more skilled crew constructed a spiraling stone staircase that climbed the inside wall of the stone castle until it reached the observation deck at the top.
                                          Finally, after many months, the castle was completed just in time to coincide with the end of the Bottomfeeders' lengthy vacation. And as you might expect upon their return, the BFs, as we will call them now, scrutinized the construction, pored over every detail and found everything perfect. The workers were brimming with pride. Then they came to the tower and Lady Bottomfeeder stood there in awe. Her eyes followed that spiral stair all the way to the top. Then her jaw dropped. 'This won't do. You must take it down at once to fix it. It's all wrong. You'd never see anything so ill-conceived in Europe. Why, we'll be the laughingstock of the entire world.'
                                          What was she talking about?
                                          dotdotdot
                                          • jeff hammondJ
                                            jeff hammond
                                            is there a prize?
                                            TIG should submit and win that thousandG!! πŸ˜„
                                            apparently, the answer (or, an answer) will be given tonight..
                                            http://www.cartalk.com/content/puzzler/
                                            edit, ha.. oh wait.. that was last week's puzzle and the answer they gave had decimal points (the same equation as one i used)
                                            i'm claiming BS πŸ’š
                                            dotdotdot
                                            • 1 / 2
