    [Preview] Skabinet (make cabinets with Sketchup)
    48 Posts 28 Posters 30.5k Views 28 Watching
    • N
      NewOne
      Hy ! I'm glad to present you a preview of a new plugin.
      It's name will be **Skabine**t, because is intended to ease furniture cabinets drawing under SketchUp.
      What you will see is just a short demonstration of what it can do. You will notice that I use Ruby Console to input a command which is not finished yet, so I didn't connected it to a button.
      %(#408000)[Short observations:
      PAL = Chipboard;
      Blat = Worktop;
      PFL = replace Plywood (that 3mm thick HDF used for cabinets back, or drawers bottom)]
      -those are material names or abbreviations from my native language (Romanian)
      %(#4000BF)[It will have more features like:
      -automatic material assignment
      -texture orientation along with first line when drawing the board
      -export Bill Of Materials
      -export cutlist in csv, xml, xls formats (with some predefined formatting, as required in some cutlist optimizing software - please tell me which ones do you use most)
      -ability to set defaults (material, thick, names, and more...) Those settings will be saved in Windows Registry or an INI file.]
      %(#BF4000)[next to add:
      -automatic clearance for doors, cabinet's back plywood
      -automatic edging
      -and more...]
      So, if you have ideas, suggestions, please don't be shy... in the end this will be a TOOL, so it must be as efficient as it can be.
      if the movie doesn't shows, whatch it here: http://www.youtube.com/watch?v=S72kdDsUFGs
      [flash=527,433:9dxw1brx]http://www.youtube.com/v/S72kdDsUFGs&hl=en_US&fs=1&color1=0xe1600f&color2=0xfebd01[/flash:9dxw1brx]
      printscreen
      • D
        dedmin
        Ha, we are neighbors! Hello from Bulgaria and Donau river! Great idea! Vote for the banding - especially in CutList format. We need a column for each part with one of the several banding formats that CutList can use:
        • TIGT
          Very good... very interesting... I watch with interest... πŸ˜‰
          • utilerU
            utiler
            Great idea, NewOne!!! Let me make a list of things to consider.....
            Just Curious...
            • N
              NewOne
              to dedmin: Only some of cutlist optimizing software accept automatic input of edging. As you may know, CutMaster 2D http://www.cutmaster2d.com/ doesn't accept this, but it accept manual input of edge banding. What software is that, of window which you are displaying?
              to TIG: thanks for your appreciation. I learned a lot from sketchucation and you (and others) helped me in the process.
              to utiler: I'm waiting for your list! πŸ˜„
              • Chris FullmerC
                You should post about this in the woodworking forum too. Point back to this thread. I'm sure you'll generate lots of interest there!
                Looks like its coming along great,
                Chris
                All my Plugins I've written
                • N
                  NewOne
                  I can't find such forum on sketchucation. Can you give me a link? 😳
                  • utilerU
                    utiler
                    Okay, had a quick look....
                    1. Option to select either top bottom or middle for the piece you are building. would be handy for dividing shelves, gables, etc.... In addition to this maybe the option to set the size of the shelf and divide into multiple shelves....
                    2. You should consider the option for a set width. Say you are layout out the bottom shelf around a corner. the way you have shown in the video is to set width one way then the other whereas choosing the extent of the whole cabinet the giving it a depth of say 600mm, choosing the side to offset and BAM!!!!
                    3. Consider a simple 'kick' function. The Kickboard is the bottom section of a cabinet that is generally 120-150mm high and offset say 50mm in from the line of the cabinet face.....
                    4. Also consider overall profiles. When we engage a cabinetmaker to make joinery he takes overall measurements and works back his thicknesses and whatever he has left is what it is.... This way we are working the opposite; building from the ground up so we need to know that the kick is 140, floor is 16, benchtop is going to be 65 then take off the rest to determine the height of the carcass.... Maybe a simple tab could be added to the dialogue box to set, your overall heights then input your known data [kicks, tops, etc to make things a little quicker...
                    Anyway, enough for now. I'll give it some more thought......
                    Great work, mate!!!
                    Just Curious...
                    • D
                      DIEGO-RODRIGUEZ
                      Hello, new one.
                      good idea, can be a great plugins.
                      some suggestions:
                      • To save, complete models (which may be modified in idem plofile builder, but the complete cabinet)
                      • Draw cabinets full , not only the panels separately (as in the video)
                      • Choice of different types of fronts. (Drawers, door panel, doors
                        with glass, doors with metal frame etc ...)
                      • Incorporate hinges and Puxadores. calculate number of hinges, Puxadores and screws
                      • If used, mdf panels for cabinets, calculate the linear feet of singing.
                      • keep in a folder, plugins folder within the busiest commercial textures used.
                        For the cabinets.
                        For example, in Argentina, almost all the cabinets that are made. plates used this company:
                        http://www.masisa.com/arg/esp/productos/tableros/270/1566/
                      plugins for view
                      • http://www.tomatoes.ch/blog/
                      • OSCarcase.rb
                      • utilerU
                        utiler
                        Diego, I would probably start with the core cabinet elements, not too often you will need to show screws and hinges; if so it will be at close detail. Hence only requiring high detail components placed where needed for detailed viewing. Otherwise the model gets overcrowded.....IMHO πŸ‘
                        Just Curious...
                        • D
                          DIEGO-RODRIGUEZ
                          utiler >
                          if, of course.
                          I only meant, that can calculate the amount of screws, hinges and Puxadores
                          the design of these elements, can be somewhat simplified or absent.
                          • N
                            NewOne
                            @diego-rodriguez said:
                            utiler >
                            if, of course.
                            You are right! This is one of my next tasks after I will finalize the first version. All those elements can be absent from model, but still counted in report. It can be made by a simple script which will add the required amount of hinges based on door's height, same with screws.
                            • utilerU
                              utiler
                              utiler >
                              if, of course.
                              SURE.... πŸ‘
                              Just Curious...
                              • dermotcollD
                                dermotcoll
                                Looks like you have the makings of a very handy tool there newone - I await further developments. Very good work so far! πŸ‘
                                When you burn your arse - you gotta sit on the blisters!!
                                • J
                                  Jack Barnhill
                                  This looks like it will be a great tool. I noticed that the description only references metric measurements. Is that determined by the plugin or does the plugin use the units set up in SketchUp?
                                  • M
                                    mics_54
                                    I don't know much about building a ruby script but I do know cabinetry construction if you need input. Customization of panels, pedestals, ladders, cletes, rabbits, dados, frameless (euro) or face front styles would make the script useful. Of course if you are a cabinet maker you are probably already aware of these things.
                                    oh..and adjustable shelves.
                                    • L
                                      linea
                                      Newone this is great,
                                      It is the plugin I would make - if I knew ruby. Cant wait to use it πŸ˜„
                                      • N
                                        NewOne
                                        I'm planning to make it adopt Sketchup's units, but for now I don't really know how.
                                        • N
                                          NewOne
                                          I learned ruby JUST to make this, believe me! You can help with ideas, instead πŸ˜„
                                          • stefanqS
                                            stefanq
                                            Excellent Andrei! I really need it! Do it!
                                            • 1 / 3
