    [Preview] Skabinet (make cabinets with Sketchup)
    48 Posts 28 Posters 30.5k Views 28 Watching
    • N
      NewOne
      @chris fullmer said:
      You should post about this in the woodworking forum too. Point back to this thread. I'm sure you'll generate lots of interest there!
      I can't find such forum on sketchucation. Can you give me a link? 😳
      • utilerU
        utiler
        Okay, had a quick look....
        1. Option to select either top bottom or middle for the piece you are building. would be handy for dividing shelves, gables, etc.... In addition to this maybe the option to set the size of the shelf and divide into multiple shelves....
        2. You should consider the option for a set width. Say you are layout out the bottom shelf around a corner. the way you have shown in the video is to set width one way then the other whereas choosing the extent of the whole cabinet the giving it a depth of say 600mm, choosing the side to offset and BAM!!!!
        3. Consider a simple 'kick' function. The Kickboard is the bottom section of a cabinet that is generally 120-150mm high and offset say 50mm in from the line of the cabinet face.....
        4. Also consider overall profiles. When we engage a cabinetmaker to make joinery he takes overall measurements and works back his thicknesses and whatever he has left is what it is.... This way we are working the opposite; building from the ground up so we need to know that the kick is 140, floor is 16, benchtop is going to be 65 then take off the rest to determine the height of the carcass.... Maybe a simple tab could be added to the dialogue box to set, your overall heights then input your known data [kicks, tops, etc to make things a little quicker...
        Anyway, enough for now. I'll give it some more thought......
        Great work, mate!!!
        Just Curious...
          DIEGO-RODRIGUEZ
          Hello, new one.
          good idea, can be a great plugins.
          some suggestions:
          • To save, complete models (which may be modified in idem plofile builder, but the complete cabinet)
          • Draw cabinets full , not only the panels separately (as in the video)
          • Choice of different types of fronts. (Drawers, door panel, doors
            with glass, doors with metal frame etc ...)
          • Incorporate hinges and Puxadores. calculate number of hinges, Puxadores and screws
          • If used, mdf panels for cabinets, calculate the linear feet of singing.
          • keep in a folder, plugins folder within the busiest commercial textures used.
            For the cabinets.
            For example, in Argentina, almost all the cabinets that are made. plates used this company:
            http://www.masisa.com/arg/esp/productos/tableros/270/1566/
          plugins for view
          • http://www.tomatoes.ch/blog/
          • OSCarcase.rb
          • utilerU
            utiler
            Diego, I would probably start with the core cabinet elements, not too often you will need to show screws and hinges; if so it will be at close detail. Hence only requiring high detail components placed where needed for detailed viewing. Otherwise the model gets overcrowded.....IMHO 👍
            Just Curious...
              DIEGO-RODRIGUEZ
              utiler >
              if, of course.
              I only meant, that can calculate the amount of screws, hinges and Puxadores
              the design of these elements, can be somewhat simplified or absent.
              • N
                NewOne
                @diego-rodriguez said:
                utiler >
                if, of course.
                You are right! This is one of my next tasks after I will finalize the first version. All those elements can be absent from model, but still counted in report. It can be made by a simple script which will add the required amount of hinges based on door's height, same with screws.
                • utilerU
                  utiler
                  utiler >
                  if, of course.
                  SURE.... 👍
                  Just Curious...
                  • dermotcollD
                    dermotcoll
                    Looks like you have the makings of a very handy tool there newone - I await further developments. Very good work so far! 👍
                    When you burn your arse - you gotta sit on the blisters!!
                      Jack Barnhill
                      This looks like it will be a great tool. I noticed that the description only references metric measurements. Is that determined by the plugin or does the plugin use the units set up in SketchUp?
                        mics_54
                        I don't know much about building a ruby script but I do know cabinetry construction if you need input. Customization of panels, pedestals, ladders, cletes, rabbits, dados, frameless (euro) or face front styles would make the script useful. Of course if you are a cabinet maker you are probably already aware of these things.
                        oh..and adjustable shelves.
                        • L
                          linea
                          Newone this is great,
                          It is the plugin I would make - if I knew ruby. Cant wait to use it 😄
                          • N
                            NewOne
                            I'm planning to make it adopt Sketchup's units, but for now I don't really know how.
                            • N
                              NewOne
                              I learned ruby JUST to make this, believe me! You can help with ideas, instead 😄
                              • stefanqS
                                stefanq
                                Excellent Andrei! I really need it! Do it!
                                  dedmin
                                  @newone said:
                                  to dedmin: Only some of cutlist optimizing software accept automatic input of edging. As you may know, CutMaster 2D http://www.cutmaster2d.com/ doesn't accept this, but it accept manual input of edge banding. What software is that, of window which you are displaying?
                                  to TIG: thanks for your appreciation. I learned a lot from sketchucation and you (and others) helped me in the process.
                                  to utiler: I'm waiting for your list! 😄
                                  This is a CutList Plus software. To export my data from SketchUP to CutList Plus I'm using CutList plugin. CutList Plus supports import of cvs or txt files. It recognizes four types of banding information:
                                  I'm using the second format and attach banding information to the name of the component using ; as a delimiter:
                                  Here is the cvs file created by the CutList plugin to be imported in CutList Plus: Untitled_CutListPlusImport.zip
                                    jhoutman
                                    Looks great! So you are creating individual boards that are components, right? Then they are grouped together in a group.
                                    How easy would the cabinet (group) be to edit or change size? I am working on a ruby that allows one to copy the whole group and automatically makes unique except where internally for the new cabinet/group, the components will not be unique to each other. If that makes sense. This part is done.
                                    The idea is to make say a prototype cabinet or drawer. Copy or clone it. Then edit its dimensions with part II of my tool and bang! you have a new cabinet.
                                    Perhaps FredoFreeScale does that. I have not check yet.
                                    • B
                                      bluecollar
                                      Hi Jhoutman
                                      I use fredoscale everday for exactly what you are describing. For instance I have a standard drawer design which i cut on a cnc router. It features sides with slots for the base panel of 6mm plywood and notching for a lap joint for front and back. In order to use the drawer in all of my cabinetry i pull it from my components window, select it, click the appropriate fredoscale scale tool(forgive me i have never taken cogniscance of its name), select the appropriate axis for redimensioning (width ,height, or depth),hit TAB key and enter the new overall dimension required.
                                      Fredoscale to my jaw dropping amazement(believe me it gives me the chills every time) resizes the drawer, keeping all the components exactly as they should be. for instance when i change the width the front and back rail extend to the appropriate length with the lap joint staying the correct depth, whilst the sides keep their thickness. when i change the height of the drawer all of the components stretch to their correct widths but the slot for the base stays the standard 15mm from the bottom and the 6.5mm wide that i need it.
                                      It is simply the most astounding and usefull script for cabinetmaking ever!
                                      • B
                                        bluecollar
                                        Hi New One
                                        Looks like you are doing an incredible thing there, I also use Cutlistplus and would welcome the edging detail export. In most of the cabinetry i do my panels are "upgraded" ie. I edge the board with solid timber of varying thicknesses, depending on the application, then veneer the board afterwards. If one had a simple edgebanding tool incorperated, say by being able to specify a edgebanding type that could then be "applied" to the appropriate edge that would be incredibly usefull.
                                        thanks in advance for what looks like a script which will further enhance su's usefullness in furniture design
                                        • bagateloB
                                          bagatelo
                                          I think that each part of the object should be adjustable. From the lid, the doors, the drawers, the baseboard. Then everything should be parametric.
                                            dedmin
                                            Please, guys! This is not SolidWorks!
                                            • 1 / 3
