    Render this: Fountain
    56 Posts 24 Posters 16.8k Views 24 Watching
    • soloS
      solo
      Hey guys, these little challenges are great fun as well as a good way to learn and teach.
      I may seem like I have too much time on my hands to be playing around like this...you are right I do, work is slow at moment (unless you have work for me šŸ’š )and playing around keeps my skills tuned as well as helping folk achieve results they may be struggling with.
      This time I think a fountain challenge would be great, we all at some point try a fountain and it most times does not turn out as well as we may hope, so let's render a fountain, complete with jetted water.
      I purposely did not add the water as this gives y'all the liberty to create splash rings, turbulence or even just a flat still surface if you like.
      Nor did I add the fountain spray, as y'all can use .png images, mesh, anything to create it.
      I also believe this will include all render engines as the last SSS exercise was limited to render engines that supported the feature.
      Have fun.
      Fountain1.skp
      http://www.solos-art.com
      • E
        Ecuadorian
        I'll try to model the water with SketchyPhysics emitters.
        -Miguel Lescano
        • soloS
          solo
          For those that want a basic water included I have attached a model with a flat water plane.
          Fountain with water.skp
          • D
            d12dozr
            Twilight Render - Spherical Sky, HDR background, Sunlight Enabled, Low+ preset.
            15 min material setup, water spray is from SU 6 Bonus pack.
            http://goo.gl/f7ooYh
            • M
              madhav
              Kerkythea
              HDRI Background
              Water Spray - Tweaked Translucent Glass
              Fountain - Marble
              MLT
              My First experiment with water mat
              • michaliszissiouM
                michaliszissiou
                The most of it is just PP (the background). But Madhav, this is a great scene, almost like painting. This is the most important thing IMO
                • E
                  Ecuadorian
                  Michalis, it's a spherical background from KT's collection; no PP is needed to add it. Here's the link to download it:
                  http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=startdown&id=44
                  -Miguel Lescano
                  • M
                    madhav
                    Thanks for your comment. yes, Its global downloaded from KT website. I have just exported model to KT, inserted global, disabled sun and applied materials. There are some other global libraries too. You just need to import the file and choose it from the drop down menu in KT.
                    • R
                      richcat
                      Here my attempt with IRender.
                      Water borrowed from 3DWH by Jam
                      • EarthMoverE
                        EarthMover
                        Nice Rich! Thanks for sharing the fountain spray you found. Ivy looks nice on the wall...I would add a concrete texture to the fountain itself with a little dirt on it.
                        Content Creator at Skapeup
                        • EarthMoverE
                          EarthMover
                          Here's something I was playing with yesterday using 3dsMax particle flow. Still needs work, but it's a start. (.gif conversion killed the quality!)
                          • soloS
                            solo
                            Very cool Adam.
                            Now if you had Realflow, you could get it to spill over and do some crazy stuff.
                            • EarthMoverE
                              EarthMover
                              Who can afford Realflow?! I contemplated Glu3D a while back for doing waterfalls and flame particles, but couldn't get the hang of it. Seems like a good alternative to Realflow for a lot less money.
                              • V
                                Vicspa
                                Recently returned from a trip to Greece, and this was found among the ruins. šŸ˜„
                                Rendered with Podium, composited in Photoshop
                                • olisheaO
                                  olishea
                                  haha good one šŸ‘ 🤣
                                  oli
                                  • soloS
                                    solo
                                    Vue.
                                    I created the splash and spray with SDS, more a bubbling fountain than a spray.
                                    • Al HartA
                                      Al Hart
                                      I took your model with water and ran it through Render nXt.
                                      Changes:
                                      • turned on the ground plane for shadows (and changed it from green to grey)
                                      • used default High Dynamic Studio lighting
                                      • Set "rubble" procedural effect on the water. Scale set to 16 for enhanced ripples. (a bird bath usually has smaller waves than an ocean)
                                      • Set 50% reflection on the water for enhanced highlighting from the sky.
                                      • Added 20% reflection to the concrete so it could have some highlighting from the sky.
                                      I let it "cook" for about 15 minutes while I took a shower.
                                      (The shadows get softer and softer the longer you let it cook)
                                      Here is the result:
                                      Al Hart
                                      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
                                      IRender nXt from Render Plus
                                      • boofredlayB
                                        boofredlay
                                        Nice one Pete.
                                        • T
                                          toxicvoxel
                                          Am I understanding this right : With nXt you can actually shower in the fountain while it is rendering?? šŸ˜„
                                          • soloS
                                            solo
                                            • 1 / 3
