    [Plugin] file_new.rb Startup, Your Way
    11 Posts 7 Posters 8.4k Views 7 Watching
      MartinRinehart
      I don't like the Line tool. I avoid it whenever possible. Naturally, I don't want to see it when I start SU, nor after File/New.
      This Ruby starts My Way. I give the "New File" item in the Plugins menu "N" as keyboard shortcut.
      Customize to make it start Your Way:
      1. You may want to delete the line that opens the Ruby Console.
      2. You may want to choose another tool. Your choices are:
      Arc, Axis, Circle, Dimension, Dolly, Erase, Extrude, FieldOf, Freehand, Line, Measure, Move, Offset, Orbit, Paint, Polygon, PositionCamera, Protractor, PushPull, Rectangle, Rotate, Scale, SectionPlane, Selection, Text, Turn, Walk, Zoom, ZoomWindow
      1. If you know Sketchup Ruby programming, the sky is the limit.
      To install: copy this code, edit as you like, and save into a file named "file_new.rb" in your Plugins directory.
      # file_new.rb - start my way!
      # Copyright 2009, Martin Rinehart
      # Forbidden; remove copyright notice; use in "how to program ..." material.
      # Permitted; everything else.
      require 'sketchup'
      def send_actions()
      	Sketchup.file_new()
      	Sketchup.send_action( 'selectSelectionTool;' )
      end # of send_actions()
      unless file_loaded?( "file_new.rb" )
      	UI.menu("Plugins").add_item( 'New File ' ) { send_actions() }
      	send_actions()
      	Sketchup.send_action( 'showRubyPanel;' )
      	file_loaded( "file_new.rb" )
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
        You could attach it to the onNewModel event. Think there was a plugin that ensured the Select tool was activated upon opening or creating new models using that event....
        • Chris FullmerC Offline
          The line tool is my favorite SU tool, with the eraser a close second, and then select comes in at No.3 I think. 😄
          And yes, someone did write a startup tool script....I don't recall who or what it was called exactly though. I never used it since I love the pencil so much 🎉
          Chris
          All my Plugins I've written
            I'm with Martin here. The pencil is usually not the tool I start to use. Select all the way! 🤓
              RickW
              Perhaps you were thinking of SelectAtStartup by yours truly 😉
              It used observers to check for SU launch, file load, and new file actions to ensure that the Select tool was the default tool any time the active model changed.
              RickW
              [www.smustard.com](http://www.smustard.com)
                MartinRinehart
                @rickw said:
                Sweet and simple, Rick. Plus, you get model opening, which I missed.
                  chrisjk
                  This doesn't seem to work for me on my setup (Mac 10.6 , latest SU Pro). Does the code need updating?
                  Chris
                    Which are you trying to use? Martin's code or Ricks?
                    Chris
                      chrisjk
                      I am trying to use Rick's code.
                      Chris
                      • X Offline
                        xrok1
                        YES! YES! YES! thankyou very much Rick. this has always bugged me since about 9 of 10 times i'm opening an existing model and have no use for the pencil. 😄 and thank you too Martin for bringing the topic up.
                        “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                          Ruturaj
                          Hello MartinRinehart,
                          Thanks you very much, 👍
                          Thanks,
                          RuturaJ
