    How do I find the face I just created with add_circle?
    10 Posts 4 Posters 920 Views 4 Watching
    • daikuD
      daiku
      I modified a component definition using entites.add_circle, now how do I find the disc-shaped face I just created?
      Clark Bremer
      http://www.northernlightstimberframing.com
      • thomthomT
        Are you maybe drawing on a face? Or using edge.find_faces afterwards?
        In any case, if you investigate one of the edges you create with .add_circle, check out it's attached faces. There might be multiple faces, but your face should be the one with the edge as part of the outer loop and have a matching normal to the circle you created.
        • thomthomT
          .add_circle only creates edges...
          • M
            MartinRinehart
            a = entities.add_circle ... # a is an array of edges
            f = entities.add_face a
            Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
            • thomthomT
              Which of course is a much more sane version to do this than my rambling.... 😳
              • daikuD
                daiku
                Or how about this brillaint (late) insight: I used the center point of the circle to add it, so I suppose I could now look for the face that point is on (DOH!). CB.
                Clark Bremer
                • thomthomT
                  ? How is looking for the face that way easier than Martin's method? AFAIK there isn't a method that returns a face from a given point. You'd have to loop through lots of geometry for that.
                  Question still remains, are you drawing the circle edges ontop of an existing face?
                  • TIGT
                    Why not make all of this new geometry - both the circle's edges and its face - inside a temporary group. Then it's easy to find the face - it's the only face in the group's entities. Afterwards explode the group back to the base entities and the face stays the same 'face-entity'...
                    • daikuD
                      daiku
                      I guess Martin's way is fine. It won't create a second face, will it? Yes, I'm creating it on an exisiting face. Looping through the geometry was straightforward - it's not that large a component.
                      Clark Bremer
                      • thomthomT
                        In that case you should only need to check the faces collection of one of the returned edges.
