    Woodworking ruby.
    44 Posts 11 Posters 14.4k Views 11 Watching
      jhoutman
      One can make the lengths independent of the units. Internally Sketchup uses inches. I read the value into a string then convert to internal with string.to_l with seems to work for me. Europeans have not complained. This should take no matter what you units are set to, into internal inches.
      Joel
        menfin
        Hello,
        Thanks.
        J have made a new attempt, by hoping to have respected your remarks.
        if you want to try again.
        Has to use with precaution.
        At the bottom of the page, before comments, new video, new plugin
          jhoutman
          menfin,
          I just installed your new version of your drilling ruby. Works great!!
          Will save time in laying out those book shelves. I would like to figure out a way of getting a suite of commonly used wood working tools all in one place. The kind of tools that furniture makers would use on a daily basis.
          Thanks for the effort.
            menfin
            I am sorry.
            J ' have still found a problem.
            I shall post a rectification tomorrow.
              menfin
              Here is the last corrected version.
              I hope that it will be good.
              drilling_milling_04_02_en
                Menfin, thank you. From a quick test, this plugin does seem to be good now.
                Thanks again.
                • E Offline
                  ebelg2000
                  Menfin, I also checked out the plugin again, and tried several different scenarios, each seemed to work well. thanks again for your efforts.
                    mics_54
                    I cannot get this to work. I create a component board, edit, place construction lines, close, select, open the drilling and milling ruby, enter anything and it does nothing. The other wood working drilling works fine.
                    Edit: figured it out! Thanks.
                      Bert
                      For the ones that does not know, I have found at the same place a very usefull ruby script called "Coupe Angulaire" that would stand for "Angle Cut"
                      Salutations (Best regards) Bert
                        dedmin
                        Perfect and very needed! Thanks! There is also a dovetail plugin!
                        • dermotcollD Offline
                          dermotcoll
                          Bert
                          I tried that page but my French is not good enough to see where the download link was for that ruby - can you post here s'il vous plait!
                          When you burn your arse - you gotta sit on the blisters!!
                            Bert
                            Hi Dermotcoll
                            If go on that page and goto Sketchup link on the left, you will have the choice of some very interesting plugins.
                            For me 3 of them are very interesting for woodworkers like me
                            one is "Queue d'arronde" which allows you to create a drawer with dovetails (If you need translation for the parameters windows, just let me know)
                            The second one is "perçage" for making holes. Usefull when you have to create many holes like for Shelving adjustemt
                            And the third one is "Coupe angulaire" or Angle cut. It allows you to cut a piece at any angles like a molding at 45 degrees
                            All theese plugins have a small vidéos showing how to.
                            Some have an english version. Whenever you see "télécharger xxx" it is the link for upload the pluging
                            • Jean-FrancoJ Offline
                              Jean-Franco
                              This plugin has already been presented here:
                              http://forums.sketchucation.com/viewtopic.php?f=183&t=19833
                              Jean-Franco
                                dedmin
                                @dermotcoll said:
                                Bert
                                Try Google translate
                                http://translate.google.com/translate?js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.premiumwanadoo.com%2Ftechnaulogis%2Fexemple_2.php&sl=fr&tl=en
                                  dermotcoll
                                  Bert, dedmin
                                  Merci beaucoup.
                                  • E Offline
                                    EvanD
                                    Where can i find the woodwrk.rb file ?
                                      Did you read the first post in the thread?
                                      In the ruby/plugin forum, I have added an update to some simple wookworking tools. They include insert component/board, resize board, a dado tool and a drill tool.
                                      The new version as some added features requested by some cabinet makers. The file is woodwrk.rb
                                      Try this.
                                        menfin
                                        Hello,
                                        There was an error, we could make a good drilling only on one face of the volume.
                                        It is now possible on every face.
                                        You can download the version 04_03_en.
                                        Please make a test.
                                        • E Offline
                                          ebelg2000
                                          I just tried the plugin for cutting angles that Bert mentioned and it seems to work quite well
                                            jhoutman
                                            In the Plugins forum I have added an update the woodwrk.rb. It is now in a folder that has the various tools broken out. It now includes ktkoh mortise/ tenon ruby. One must copy the runwoodwrk.rb into the plugins folder. One can then edit that file to delete out any ruby's you don't want or add your own.
                                            Thanks,
                                            Joel
                                            • 2 / 3
