    Woodworking ruby.
    44 Posts 11 Posters 17.0k Views 11 Watching
      I don't see why there needs to be a metric version and an imperial version. Others write plugins that get the model units. Why doesn't this plugin do that?
      I did set the depth to the thickness of the "board" but only one of ten holes was punched through. At this point, the plugin isn't useful to me at all.
        menfin
        hello
        I am sorry, for these inconveniences.
        I am going to work again on it.
        My ruby is also poor as my English...
        • E
          ebelg2000
          menfin, excellent work! I loaded the plugin and it seems to work well. The only question I have is it appears like I can only input integer values for the diameter and depth of the hole. How would I input for a 1/2" diameter hole?
          Thanks again for your efforts!
            jhoutman
            One can make the lengths independent of the units. Internally Sketchup uses inches. I read the value into a string then convert to internal with string.to_l with seems to work for me. Europeans have not complained. This should take no matter what you units are set to, into internal inches.
            Joel
              menfin
              Hello,
              Thanks.
              J have made a new attempt, by hoping to have respected your remarks.
              if you want to try again.
              Has to use with precaution.
              At the bottom of the page, before comments, new video, new plugin
                jhoutman
                menfin,
                I just installed your new version of your drilling ruby. Works great!!
                Will save time in laying out those book shelves. I would like to figure out a way of getting a suite of commonly used wood working tools all in one place. The kind of tools that furniture makers would use on a daily basis.
                Thanks for the effort.
                  menfin
                  I am sorry.
                  J ' have still found a problem.
                  I shall post a rectification tomorrow.
                    menfin
                    Here is the last corrected version.
                    I hope that it will be good.
                    drilling_milling_04_02_en
                      Menfin, thank you. From a quick test, this plugin does seem to be good now.
                      Thanks again.
                      • E
                        ebelg2000
                        Menfin, I also checked out the plugin again, and tried several different scenarios, each seemed to work well. thanks again for your efforts.
                          mics_54
                          I cannot get this to work. I create a component board, edit, place construction lines, close, select, open the drilling and milling ruby, enter anything and it does nothing. The other wood working drilling works fine.
                          Edit: figured it out! Thanks.
                          • B
                            Bert
                            For the ones that does not know, I have found at the same place a very usefull ruby script called "Coupe Angulaire" that would stand for "Angle Cut"
                            Salutations (Best regards) Bert
                              dedmin
                              Perfect and very needed! Thanks! There is also a dovetail plugin!
                              • dermotcollD
                                dermotcoll
                                Bert
                                I tried that page but my French is not good enough to see where the download link was for that ruby - can you post here s'il vous plait!
                                When you burn your arse - you gotta sit on the blisters!!
                                • B
                                  Bert
                                  Hi Dermotcoll
                                  If go on that page and goto Sketchup link on the left, you will have the choice of some very interesting plugins.
                                  For me 3 of them are very interesting for woodworkers like me
                                  one is "Queue d'arronde" which allows you to create a drawer with dovetails (If you need translation for the parameters windows, just let me know)
                                  The second one is "perçage" for making holes. Usefull when you have to create many holes like for Shelving adjustemt
                                  And the third one is "Coupe angulaire" or Angle cut. It allows you to cut a piece at any angles like a molding at 45 degrees
                                  All theese plugins have a small vidéos showing how to.
                                  Some have an english version. Whenever you see "télécharger xxx" it is the link for upload the pluging
                                  • Jean-FrancoJ
                                    Jean-Franco
                                    This plugin has already been presented here:
                                    http://forums.sketchucation.com/viewtopic.php?f=183&t=19833
                                    Jean-Franco
                                      dedmin
                                      @dermotcoll said:
                                      Bert
                                      Try Google translate
                                      Error 404 (Not Found)!!1
                                      (translate.google.com)
                                      • dermotcollD
                                        dermotcoll
                                        Bert, dedmin
                                        Merci beaucoup.
                                        • E
                                          EvanD
                                          Where can i find the woodwrk.rb file ?
                                            Did you read the first post in the thread?
                                            In the ruby/plugin forum, I have added an update to some simple wookworking tools. They include insert component/board, resize board, a dado tool and a drill tool.
                                            The new version as some added features requested by some cabinet makers. The file is woodwrk.rb
                                            Try this.
                                            • 2 / 3
