    Woodworking ruby.
    44 Posts 11 Posters 15.5k Views 11 Watching
      dedmin
      Perfect and very needed! Thanks! There is also a dovetail plugin!
      • dermotcollD Offline
        dermotcoll
        Bert
        I tried that page but my French is not good enough to see where the download link was for that ruby - can you post here s'il vous plait!
        When you burn your arse - you gotta sit on the blisters!!
          Bert
          Hi Dermotcoll
          If go on that page and goto Sketchup link on the left, you will have the choice of some very interesting plugins.
          For me 3 of them are very interesting for woodworkers like me
          one is "Queue d'arronde" which allows you to create a drawer with dovetails (If you need translation for the parameters windows, just let me know)
          The second one is "perçage" for making holes. Usefull when you have to create many holes like for Shelving adjustemt
          And the third one is "Coupe angulaire" or Angle cut. It allows you to cut a piece at any angles like a molding at 45 degrees
          All theese plugins have a small vidéos showing how to.
          Some have an english version. Whenever you see "télécharger xxx" it is the link for upload the pluging
          Salutations (Best regards) Bert
          • Jean-FrancoJ Offline
            Jean-Franco
            This plugin has already been presented here:
            http://forums.sketchucation.com/viewtopic.php?f=183&t=19833
            Jean-Franco
              dedmin
              @dermotcoll said:
              Bert
              Try Google translate
              Google Translate
              (translate.google.com)
                dermotcoll
                Bert, dedmin
                Merci beaucoup.
                • E Offline
                  EvanD
                  Where can i find the woodwrk.rb file ?
                    Did you read the first post in the thread?
                    In the ruby/plugin forum, I have added an update to some simple wookworking tools. They include insert component/board, resize board, a dado tool and a drill tool.
                    The new version as some added features requested by some cabinet makers. The file is woodwrk.rb
                    Try this.
                      menfin
                      Hello,
                      There was an error, we could make a good drilling only on one face of the volume.
                      It is now possible on every face.
                      You can download the version 04_03_en.
                      Please make a test.
                      • E Offline
                        ebelg2000
                        I just tried the plugin for cutting angles that Bert mentioned and it seems to work quite well
                          jhoutman
                          In the Plugins forum I have added an update the woodwrk.rb. It is now in a folder that has the various tools broken out. It now includes ktkoh mortise/ tenon ruby. One must copy the runwoodwrk.rb into the plugins folder. One can then edit that file to delete out any ruby's you don't want or add your own.
                          Thanks,
                          Joel
                            dedmin
                            Hi Dermotcoll
                            Anybody has the "Coupe angulaire" plugin - the links are dead?
                              Bert
                              Hi Dedmin,
                              Yvon, the guy behind those plugins has mentionned that his web site is beeing reworked
                              and that the plugins should be availlable again in a near future
                              Send me a PM with your e-mail and I will send you the plugin
                                dedmin
                                Thanks, bert!
                                  dedmin
                                  Seems there is a new version for the SU8 - http://www.premiumwanadoo.com/technaulogis/exemple_5.php
                                  • 2 / 3
