    Woodworking ruby.
    44 Posts 11 Posters 17.0k Views 11 Watching
      mics_54
      I cannot get this to work. I create a component board, edit, place construction lines, close, select, open the drilling and milling ruby, enter anything and it does nothing. The other wood working drilling works fine.
      Edit: figured it out! Thanks.
      • B
        Bert
        For the ones that does not know, I have found at the same place a very usefull ruby script called "Coupe Angulaire" that would stand for "Angle Cut"
        Salutations (Best regards) Bert
          dedmin
          Perfect and very needed! Thanks! There is also a dovetail plugin!
          • dermotcollD
            dermotcoll
            Bert
            I tried that page but my French is not good enough to see where the download link was for that ruby - can you post here s'il vous plait!
            When you burn your arse - you gotta sit on the blisters!!
            • B
              Bert
              Hi Dermotcoll
              If go on that page and goto Sketchup link on the left, you will have the choice of some very interesting plugins.
              For me 3 of them are very interesting for woodworkers like me
              one is "Queue d'arronde" which allows you to create a drawer with dovetails (If you need translation for the parameters windows, just let me know)
              The second one is "perçage" for making holes. Usefull when you have to create many holes like for Shelving adjustemt
              And the third one is "Coupe angulaire" or Angle cut. It allows you to cut a piece at any angles like a molding at 45 degrees
              All theese plugins have a small vidéos showing how to.
              Some have an english version. Whenever you see "télécharger xxx" it is the link for upload the pluging
              • Jean-FrancoJ
                Jean-Franco
                This plugin has already been presented here:
                http://forums.sketchucation.com/viewtopic.php?f=183&t=19833
                Jean-Franco
                  dedmin
                  @dermotcoll said:
                  Bert
                  Try Google translate
                  Error 404 (Not Found)!!1
                  (translate.google.com)
                  • dermotcollD
                    dermotcoll
                    Bert, dedmin
                    Merci beaucoup.
                    • E
                      EvanD
                      Where can i find the woodwrk.rb file ?
                        Did you read the first post in the thread?
                        In the ruby/plugin forum, I have added an update to some simple wookworking tools. They include insert component/board, resize board, a dado tool and a drill tool.
                        The new version as some added features requested by some cabinet makers. The file is woodwrk.rb
                        Try this.
                          menfin
                          Hello,
                          There was an error, we could make a good drilling only on one face of the volume.
                          It is now possible on every face.
                          You can download the version 04_03_en.
                          Please make a test.
                          • E
                            ebelg2000
                            I just tried the plugin for cutting angles that Bert mentioned and it seems to work quite well
                              jhoutman
                              In the Plugins forum I have added an update the woodwrk.rb. It is now in a folder that has the various tools broken out. It now includes ktkoh mortise/ tenon ruby. One must copy the runwoodwrk.rb into the plugins folder. One can then edit that file to delete out any ruby's you don't want or add your own.
                              Thanks,
                              Joel
                                dedmin
                                Hi Dermotcoll
                                Anybody has the "Coupe angulaire" plugin - the links are dead?
                                • B
                                  Bert
                                  Hi Dedmin,
                                  Yvon, the guy behind those plugins has mentionned that his web site is beeing reworked
                                  and that the plugins should be availlable again in a near future
                                  Send me a PM with your e-mail and I will send you the plugin
                                    dedmin
                                    Thanks, bert!
                                      dedmin
                                      Seems there is a new version for the SU8 - http://www.premiumwanadoo.com/technaulogis/exemple_5.php
                                      • 2 / 3
