    [req] help with simple plugin
    10 Posts 3 Posters 1.2k Views 3 Watching
    • G Offline
      georglorenz
      Hi, I am new to ruby scripting and amazed by the possibilities. I am trying to write a simple script that distorts the geometry of all selected faces by a random amount.
      I first triangulate all selected faces with TIGs triangulateFaces that I call from within the script which works fine. Then I want to transform each vertices of every face by a random x,y,and z amount.
      with my limited programming experience I am so far unable to get it going. Here is what I thought:
      for f in faces
      for v in f.vertices
      v.position = v.position + [xrand,yrand,zrand]
      end #for
      end #for
      But that (and 23 other options I tried) does not work. Can anyone help me here?
        Jim
        It's a good thought, but as you found out - it doesn't work that way.
        To move vertices, faces, and edges you will need to go through the Entities collection.
        Something like should work:
        for f in faces
        for v in f.vertices
          tr = Geom;;Transformation.new(v.position + [xrand,yrand,zrand])
          Sketchup.active_model.entities.transform_entities(tr, v)
        end #for
        end #for
          You will need a line the define xrand etc...
          Something like...
          xrand=10*rand
          and the same for yrand and zrand - the 10* give an offset between 0" and 10"...
          This only adds to the vertex position - you need another line transforming the vertices in the -ve, like
          xrand=-10*rand etc afterwards ?
          • G Offline
            georglorenz
            Ok. Thank you guys. Almost there. The main method works fine in the webconsole, but when I save it as a script it tells me: "distort.rb:42: parse error, expecting `kEND'", which I guess means that end end is missing in line 42 (before the menu).
            I seriously have no Idea why. Please help me!
            # gl_distort
            require 'sketchup.rb'
            def GL_distort
            model = Sketchup.active_model
            entities = model.entities
            selection = model.selection
            prompts = ['Random Distortion Distance']
            defaults = [0.to_l]
            results = UI.inputbox prompts, defaults, 'Distance for random distortion;'
            distance = results [0]
            model.start_operation "Distort"
            selection.each do |e|
            	if (e.is_a? Sketchup;;Face)
               		for v in e.vertices
                       		xrand=(-distance/2)+distance*rand
                       		yrand=(-distance/2)+distance*rand
                       		zrand=(-distance/2)+distance*rand
                       		# puts(xrand, yrand, zrand)
                       		vector = Geom;;Vector3d.new xrand,yrand,zrand
                       		tr = Geom;;Transformation.translation vector
                    	end #for
            	end #if
            end #do
            model.commit_operation
            end #main
            ### Menu ###
            if not file_loaded?(__FILE__)
              UI.menu("Plugins").add_item("Distort"){GL_distort}
            end #if
            file_loaded(__FILE__)
              Change from GL_distort to gl_distort a def must start with a lowercase letter...
              • G Offline
                georglorenz
                still the same error...
                  Changed every GL_distortto lowercase ?
                  Works fine for me...
                  • G Offline
                    georglorenz
                    yes. both of them. thank you. I guess it has something to do with the "for v in e.vertices loop". If I take it out completely it parses fine. Can it be that something would not work in Sketchup 6? I am still running v6 on a mac. Strange thing is: it runs fine in the webconsole. Any idea how to resolve this?
                    Thanks for your time. G
                      This is my version that works fine in v7.
                      Try it in v6...#gl_distort.rb
                      • G Offline
                        georglorenz
                        TIG: Thank you. It works. Don't ask me why. Your and my code are identical with the exception of a couple of blank lines. I checked that twice and then again. And side by side. And then again. And I have no idea. But it its working. πŸ˜„
                        I added input for xyz coordinates as you can see on the image. The crinkled surface was distorted only along the z axis, the top plane of the cube was distorted in three dimensions.
                        This is just for fun. Please use at your own risk and save before using. It crashed on me a couple of times already.
                        Thank you much for all your time. G
                        gl_xyzdistort.rb
