    Using an item's bounding box as an anchor point?
    4 Posts 4 Posters 1.1k Views 4 Watching
    • A
      agamemnus
      Ok, I'm going to be asking a lot of questions so I'll just noob myself up right now!
      Is there any way to use an item's (group or component) bounding box as an anchor point, or alternatively create the bounding box as a separate rectangular group?
      • Chris FullmerC
        No, there is currently no way to use a group's bounding box as an anchor to snap to. Interesting idea though.
        Chris
        All my Plugins I've written
        • TIGT
          You could of course add 8 very tiny 'snap' components to the bb's corners and then refer to those for the snapping actions ? The bb wouldn't change because the 8 new items would be inside it ??
          • Jean LemireJ
            Jean Lemire
            Hi folks.
            I would try this:
            1 - Make a group or a component with the object.
            2 - Inside the group or component, I would create another nested group that will contain a simple rectangular box having its dimensions adjusted to contain exactly the object. This is very easy to do with the Rectangle Tool and the Push/Pull Tool using the object itself to control the pulls or the pushes.
            3 - I would hide this box.
            4 - Then, whenever I need to grab the "bounding box" of an object, I would first show hidden geometry and then move the object using any suitable points on that box.
            Of course, using scenes to memorize settings like "show hidden geometry" or not would help greatly. Just a click on a scene tab and I am set to grab and move. Another click and the box or boxes are hidden. Using layers could also be possible to control the visibility of these boxes.
            Just ideas.
