    Deleting all hidden geometry
    18 Posts 6 Posters 18.5k Views 6 Watching
    • E Offline
      ericschimel
      Being a bit of a rookie at Ruby, does anyone out there know if its possible to write a script that would select, and delete all hidden geometry from a model?
      -Eric
      http://plugin.sketchthis.net
      Sketchup Kitchen Design Plugin
      Custom Models
        Untested, but I think this should work. (SU7)
        Sketchup.active_model.start_operation('Erase all Hidden geometry', true)
        ents = []
        Sketchup.active_model.entities.each { |e|
          ents << if e.hidden? || e.layer.hidden?
        Sketchup.active_model.entities.erase_entities(ents)
        Sketchup.active_model.definitions.each { |d|
          next if d.image?
          ents = []
          d.entities.each { |e|
          d.entities.erase_entities(ents)
        Sketchup.active_model.commit_operation
        Not sure if you also count Soft edges as hidden?
          It'd be quite easy to do... BUT... if something is 'connected' to other stuff you'd get unexpected problems.
          For example, if a hidden Edge is forming a visible Face then erasing the Edge erases the Face too ! Which you'd probably NOT want ??
          Exactly what 'Hidden Geometry' are we talking about here ? Hidden Groups/Instances, or other hidden 'raw geometry' like Edges/Faces?
          If it's 'all' of these then you'll need to trap for connectivity across the hidden/visible divide - like my Faced-Edge example...
          If it's stuff on a 'hidden' layer then cross connectivity still applies - there's 'hidden-entities' and entities on 'hidden-layers' - two separate things with similar outcomes...
          Please give us a bit more detail - then it'd be relatively easy to do... but the why is the most important part... So we could tailor the outcome to what you want... ❓
          • Chris FullmerC Offline
            I suppose it could check each edge before deleting to test if it is connected to a visible face. It is is, then instead of deleting the edge, it should probably just unhide it. That might work for edges.
            Chris
            All my Plugins I've written
            • E Offline
              ericschimel
              Wow! I was just looking to see if that was even possible, I didn't mean for you guys to go and do half the work for me! I really appreciate it though!!
              Here is what I am trying to accomplish:
              I have some custom DC's that I use to make models with... I want to be able to send these models out, but I don't want the people I am sending them to to have the DC's.........
              I am basically trying to see if its possible to write a script that will delete all hidden geometry in the model (As there a lot of options in my DC's that hide, and unhide things) AND I would like the script to explode the entire model down to raw geometry (this part I already know is possible)
              I would obviously do a SAVE AS right before I did this, so I could edit my original model... Perhaps Ruby could save the file for me.... (FILENAME_EXPLODED.SKP)
              -Eric
              Custom Models
                model.save
                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/model.html#save
                So it's be
                • Save Model As
                • Erase all hidden Components (All Components in DC's only?)
                • Kaboooom!
                • Save
                • E Offline
                  ericschimel
                  You've pretty much got it!
                  My hope is, after all the hidden geometry is deleted, that the DC's don't get whacky before they are exploded...
                  -Eric
                  Custom Models
                    hmm... Maybe removing the DC attributes before erasing..?
                      But only remove components located inside DCs?
                      • E Offline
                        ericschimel
                        Removing the hidden ones just inside the DC's would be nice if the script could be that smart... Not necessary though... It could just delete all hidden geometry in the model...
                        Do you think there is a way to make a plugin that would strip DC's of all their "smartness"?
                        -Eric
                        Custom Models
                          It's possible to remove the attribute_dictionaries, yes. It's from them you can detect if a component is a DC.
                          But I'm not sure about any observers attached to the DC. Maybe there's some hidden API to control that..?
                          • E Offline
                            ericschimel
                            That would be nice if you could do that....
                            However, simply exploding everything in the model should cause the DC's to lose all their attributes anyway...
                            As long as I can get rid of the hidden geometry, which shows itself when exploded, I would be good...
                            -Eric
                            Custom Models
                              Jim
                              I'm not 100% certain of how they work internally, but it would seem if simply exploding a DC and vaporizing the attribute dictionary caused a failure of SketchUp, it would be a major issue and would have come up already.
                              • E Offline
                                ericschimel
                                I just realized that I would have to "Purge Unused" from the model as well to get rid of all the components...
                                I would assume that is easy to access via ruby as well....
                                -Eric
                                Custom Models
                                  Yes.
                                  I won't have time to look at this for a few days - if any of the other scripters got a few spare minutes..?
                                  • E Offline
                                    ericschimel
                                    Don't let me stop you if you want to... I was just trying to get a sense of the possibility of all of this. Im going to start researching the Ruby code site and see what I can come up with...
                                    -Eric
                                    Custom Models
                                      Well, it's a nice little starter project if you're new to ruby and sketchup plugin scripting.
                                      • jcztJ Offline
                                        jczt
                                        Hello to all,
                                        12 years later... Sorry.
                                        I am working on model with a lot of DCs, and the .csv export of "attrreporter.rb" takes several time.
                                        The TomTom's solution "model.save" maybe can hepl me.
                                        Does Someone keep it safe?
                                        Thank you for your answers.
                                        Julien
