    Deleting all hidden geometry
    18 Posts 6 Posters 19.3k Views 6 Watching
    • Chris FullmerC
      I suppose it could check each edge before deleting to test if it is connected to a visible face. It is is, then instead of deleting the edge, it should probably just unhide it. That might work for edges.
      • E
        ericschimel
        Wow! I was just looking to see if that was even possible, I didn't mean for you guys to go and do half the work for me! I really appreciate it though!!
        Here is what I am trying to accomplish:
        I have some custom DC's that I use to make models with... I want to be able to send these models out, but I don't want the people I am sending them to to have the DC's.........
        I am basically trying to see if its possible to write a script that will delete all hidden geometry in the model (As there a lot of options in my DC's that hide, and unhide things) AND I would like the script to explode the entire model down to raw geometry (this part I already know is possible)
        I would obviously do a SAVE AS right before I did this, so I could edit my original model... Perhaps Ruby could save the file for me.... (FILENAME_EXPLODED.SKP)
        -Eric
        http://plugin.sketchthis.net
        Sketchup Kitchen Design Plugin
        Custom Models
          model.save
          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/model.html#save
          So it's be
          • Save Model As
          • Erase all hidden Components (All Components in DC's only?)
          • Kaboooom!
          • Save
          • E
            ericschimel
            You've pretty much got it!
            My hope is, after all the hidden geometry is deleted, that the DC's don't get whacky before they are exploded...
            -Eric
            Custom Models
              hmm... Maybe removing the DC attributes before erasing..?
                But only remove components located inside DCs?
                • E
                  ericschimel
                  Removing the hidden ones just inside the DC's would be nice if the script could be that smart... Not necessary though... It could just delete all hidden geometry in the model...
                  Do you think there is a way to make a plugin that would strip DC's of all their "smartness"?
                  -Eric
                  Custom Models
                    It's possible to remove the attribute_dictionaries, yes. It's from them you can detect if a component is a DC.
                    But I'm not sure about any observers attached to the DC. Maybe there's some hidden API to control that..?
                    • E
                      ericschimel
                      That would be nice if you could do that....
                      However, simply exploding everything in the model should cause the DC's to lose all their attributes anyway...
                      As long as I can get rid of the hidden geometry, which shows itself when exploded, I would be good...
                      -Eric
                      Custom Models
                        Jim
                        I'm not 100% certain of how they work internally, but it would seem if simply exploding a DC and vaporizing the attribute dictionary caused a failure of SketchUp, it would be a major issue and would have come up already.
                        • E
                          ericschimel
                          I just realized that I would have to "Purge Unused" from the model as well to get rid of all the components...
                          I would assume that is easy to access via ruby as well....
                          -Eric
                          Custom Models
                            Yes.
                            I won't have time to look at this for a few days - if any of the other scripters got a few spare minutes..?
                            • E
                              ericschimel
                              Don't let me stop you if you want to... I was just trying to get a sense of the possibility of all of this. Im going to start researching the Ruby code site and see what I can come up with...
                              -Eric
                              Custom Models
                                Well, it's a nice little starter project if you're new to ruby and sketchup plugin scripting.
                                • jcztJ
                                  jczt
                                  Hello to all,
                                  12 years later... Sorry.
                                  I am working on model with a lot of DCs, and the .csv export of "attrreporter.rb" takes several time.
                                  The TomTom's solution "model.save" maybe can hepl me.
                                  Does Someone keep it safe?
                                  Thank you for your answers.
                                  Julien
