    How to place a PNG image as a label on a bottle...
    renderpluginsextensions
    3 Posts 2 Posters 1.1k Views 2 Watching
      Click Draw
      What is the proper method of placing a PNG image on a model as a texture and preserve the transparency when it is rendered. I use V-Ray and am wondering if it is a V-Ray setting or a Sketchup issue....?
      Thanks,
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
        V-Ray doesn't read the transparency information in PNG images - or any formats.
        You must supply the transparency in a separate grayscale image and load that into the transparency slot in the diffuse channel.
          Click Draw
          Ok, so if I were wanting to make a bottle that is red and I wanted to apply a label. Listed is what I would have to do?:
          • make bottle and paint red
          • import texture and apply the label image.
          • in V-Ray material window, select diffuse tab, click transparent and make white.
          • in diffuse tab, click "m" on transparent select bitmap on common drop down.
          • click "m" in bitmap and select a grey scale of the label graphic.
          And that's it? I must be missing something. When I do it like this, the bottle turns transparent red.
          Jeff 😞
