    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] CleanUp
    974 Posts 217 Posters 860.8k Views 217 Watching
      Tahesco
      Hi ThomThom,
      We imported a 100mb model from ARCHICAD into SU (in fbx format). This goes slow but it works.
      The problem is the same material gives different uvw_sizes on my components. The same brick material is 1 cm on a component while it's neigbour component has bricks of 20 cm ?!?.
      Is there a way to reset all components to the same scale, so my bricks are uniform on all objects/ components? (like reset xform in 3dsmax)
      Thanks for all the usefull work!
      TTion
      • bagateloB Offline
        bagatelo
        Another thing to do would be also interesting can recursively set all groups and components to "scale definition."
        @tahesco said:
        Hi ThomThom,
        TTion
          And how would you handle scenarios where one definition has instances of different scale... ?
            Tahesco
            In my case I don't care if I loose all instances. All scene objects may become true default geometry. (because my scene objects are build in ARCHICAD).
            Thanks again,.
            NB -> Maybe an object replacer-script is capable of repairing killed Insances in a SU scene,...
            • sumasterS Offline
              sumaster
              Hello Tahesco,
              can you CHK Unit ... when you export the file from ARCHICAD into .fbx format
              so 1st CHK and again import that .fbx file into the sketchup same unit select ......
              thanks
              Thank you,
              SUmaster
              • sumasterS Offline
                sumaster
                @thomthom said:
                @thomthom said:
                The way CleanUp traverses the model it's tricky to know what is part of a locked group or not. But I'll put it down for investigation.
                You can use ruby to check if is locked or not
                http://code.google.com/apis/sketchup/docs/ourdoc/group.html#locked?
                http://code.google.com/apis/sketchup/docs/ourdoc/componentinstance.html#locked?
                I know, but, I traverse the model by model.definitions.each - which means that I do not know if the parent for the instances I traverse are locked. I could be checking a sub-group of a locked group and .locked? will return false.
                yes sir you are right .......
                when run Cleanup last setting he CHK all group or component ..... right ...?
                Thank you,
                SUmaster
                • genma saotomeG Offline
                  genma saotome
                  VERY useful! ๐Ÿ˜ My thanks for producing and releasing this.
                  Might you consider adding "Remove Materials" from Backface? I know it's in another plugin but it's something I should do as part of my final cleanup but I often forget. Adding this would to Cleanup would be real handy and I would like to see the count of cleaned backfaces in the statistics too.
                  P.S.
                  Ya know, adding "Remove Untextured Faces" would be a godsend for me. Any chance of that too?
                  • 0 Offline
                    0devang
                    It doesn't work with sketchup pro 8. what could be the reason?
                      The plugin does indeed work with SketchUp 8 Pro. If it isn't working for you, the most likely cause is that it hasn't been installed correctly. Go back to the first post and read the instructions and make sure it has been installed correctly. This includes installing TT_Lib2 as indicated under Requirements.
                        P.S.
                        I'll see what I can do for the next release. (I'm quite busy atm, can't promise anything.)
                        • dereiD Offline
                          derei
                          Indeed, a "remove materials from back face", but applicable only to selection (or entire model if nothing selected" would be great! The current plugin that does it, removes from entire model. And I often have windows (with or without thickness), or other transparent materials and they start to look bad after removing backface material.
                          DESIGNER AND ARTIST DEREI.UK
                          • O Offline
                            oggstreamer
                            Hello thomthom,
                            i am eager to use your CleanUp Plugin - but i've some troubles installing it - i am using Sketchup 8 under WINE
                            I installed both CleanUp 3.1.8 and TT_Lib2 2.6.0 in the plugin-Directory. and i get the following Error:
                            Error Loading File tt_cleanup.rb
                            uninitialized constant TT::System
                            do you have any Hint for me?
                            thanks, georg
                              that's the whole error message?
                              If yes, then could you open the Ruby Console in SketchUp and type load 'tt_cleanup.rb' and see if you get a more verbose error message then?
                              Other than that, maybe a screenshot of how CleanUp and TT_Lib2 is installed in your plugins folder?
                              • jeff hammondJ Offline
                                jeff hammond
                                [Feature Request]
                                Weld all lines... not sure if it's possible or maybe it will take too long but it'd be sweet to weld everything in one shot.
                                dotdotdot
                                  Weld all edges between junctions?
                                  That can be done with Edge Tools already if you use the Simplify Selected Curves and specify 0 deviation.
                                  • O Offline
                                    oggstreamer
                                    about the WINE Problem
                                    starting it via Ruby Console gives a lot of Warnings and an Error:
                                    Error: #<NameError: C:/Programme/Google/Google SketchUp 8/Plugins/TT_Lib2/webdialog_patch.rb:10: uninitialized constant TT::System>
                                    C:/Programme/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:79
                                    C:/Programme/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:400:in require' C:/Programme/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:400 C:/Programme/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb:399:in each'
                                    C:/Programme/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:79:in require' C:/Programme/Google/Google SketchUp 8/Plugins/tt_cleanup.rb:79 (eval):79:in load'
                                    I think the Directory-Structure is ok - because i tried your plugin in VirtualBox today - and it works like a charm - Great Plugin btw.
                                    thanks,
                                    Georg
                                    tt_cleanup_wine_error.txt
                                      hm... this is odd... but could you try something?
                                      Open webdialog_patch.rb and insert two new lines at the top of the file:
                                      require 'TT_Lib2/core.rb' require 'TT_Lib2/system.rb'
                                      Not sure why only you get this, but maybe there's some quirk in that it runs under Wine...
                                      • O Offline
                                        oggstreamer
                                        yes - i am one step further. The plugin loads now - but the Plugins->CleanUp3->Clean... shows an empty Windows. Maybe i have to install IExplorer?
                                        thanks
                                        • O Offline
                                          oggstreamer
                                          I will leave it like that - the Merge Faces and erase hidden geometry works! and thats fine for me
                                            ๐Ÿ‘ I will add the changes to the next release.
                                            The window is a webdialog, which under windows use an embedded Internet Explorer window and under OSX it uses an embedded WebKit.
                                            It's been a while since I tried Ubuntu, but I used to have an old machine with it and I tried SU a couple of times. But I usually got crashes - when I didn't I got problems with webdialogs.
                                            But not sure what the status is now though - a couple of years later...
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 48
                                            • 49
                                            • 25 / 49
