    [Plugin] CleanUp
    974 Posts 217 Posters 834.0k Views 217 Watching
      @honoluludesktop said:
      Hi Thomas, I lost a texture from a face in a 61k faces model. BTW what happens when you have coplaner faces with different textures, or images placed on textured faces (say a run on a wood floor).
      At the moment it doesn't take into account materials. Only geometry.
      Images? You mean an actual Image entity (It says "Image" in Entity Info when you select it?)
        Well, I often import images (as images, not textures), and place them on textured faces.
        They would be ignored.
        However, I do plan on adding an option for it to respect the material of the geometry. Just got to sort out some other issue first.
        • honoluludesktopH Offline
          honoluludesktop
            honoluludesktop
            Opps, added image after your post.
              Seems another very useful plug β˜€
              About the Ecuadorian file
              Why not scale the file *10, apply the plug, then scale 1/10 ? πŸ˜‰
                The scale isn't the issue.
                  chango70
                  This works very well. I have made Ctrl Shift C short cut for it. Thank you!
                    @jim said:
                    Ack! it doesn't look at materials?
                    Oh, and thank you! πŸ‘
                    Hi Thomas, I lost a texture from a face in a 61k faces model. BTW what happens when you have coplaner faces with different textures, or images placed on textured faces (say a run on a wood floor). Didn't read all the post, so sorry if already covered.
                    Option to respect materials applied added. On by default.
                    Ecuadorian:
                    I adjusted the tolerance so it shouldn't loose any geometry on the model you sent me. Hopefully it won't loose anything in other models either.
                    But there is some cases where which can be removed is left behind. I hope to address this. I figured it's best to be defensive than aggressive.
                    • E Offline
                      Ecuadorian
                      Sounds nice, Thom!
                      Perhaps you could give the user two or three threshold options.
                      -Miguel Lescano
                        @ecuadorian said:
                        Sounds nice, Thom!
                        I added an debug option which you can use for now. You can see it in the screenshot.
                        The closer to 1.0 the stricter it is.
                          @ecuadorian said:
                          Sounds nice, Thom!
                          As for the model you sent me, you won't have much luck reducing the tolerance because of the threshold where the edges can be removed overlaps. That model is a good example of a troublesome model - I'll try and get some Google heads to comment on what's going on.
                          • I Offline
                            ideas_arte
                            incredibly helpful, thank you very much πŸ˜„
                            • N Offline
                              notareal
                              πŸ‘
                              Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                Updated once again.
                                Now has a dialog window where you can set various cleanup operation to be run on the entire model. Settings are persistent per session only.
                                  😳 minor update to control whether to erase lonely edges or not - and corrected the purge order.
                                    😳 😳 Yet another bug fix.
                                    Ok! Enough! Weekend!
                                    • plot-parisP Offline
                                      plot-paris
                                      fantastic plugin, Thom,
                                      I already had my shortcut Ctrl+Shift+D assigned to the first cleanup-script. but the new one seems to be a lot more powerful. already worked well on models that lost lots of faces when cleaned up in the past.
                                      about the threshold: do you think instead (or in addition maybe) to the manual input, would it make sense to have predefined settings, like 'high', 'medium' and 'low'?
                                      cause adding nines to the 0.9999 isn't very intuitive... on the other hand. might be a bit too much... πŸ˜•
                                      thanks again for the plugin. cleanup is one of the tools that I use most. couldn't live without it!
                                      have a nice weekend!
                                      • F Offline
                                        Fletch
                                        this looks killer, ThomThom... sure would have helped a lot with that 3ds Classroom model... I just basically re-built it from scratch instead πŸ˜’
                                        Fletch
                                        Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                                        • majidM Offline
                                          majid
                                          πŸ‘ πŸ‘
                                            I'm trying to get hold of feedback from Google which can shed some light on how things works under the hood in SU so I can 100% reliably erase all edges that are coplanar. I want to avoid having to set this tolerance completely.
                                            But until then we have this tolerance. But I do plan on eventually implement a webdialog that will provide a better UI this this. More specifically, giving a better description of the various options as I don't feel the current UI is quite clear on what it do. With webdialogs I can add sliders etc. Will have to see though. I want to try to get feedback from Google before I invest time in that.
                                            • 48
                                            • 49
                                            • 2 / 49
