    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      I think I might have misunderstood this whole DOT product from vectors... will have to look deeper into it.
      • Chris FullmerC
        Can you hit ctrl-z in ruby? πŸ˜„
          remus
          What do you think is not working? from my quick browse of your script the dot product should do what you want.
            Yea, http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/sketchup.html#undo
            But that would ruin any kind of possibility to undo the whole erase coplanar operation.
              ...could create a temp group and use that to replicate the two faces (when within a range where we can't be certain.)
              but I'd still try to avoid that if I can calculate this.
              • honoluludesktopH
                honoluludesktop
                Hi Thomas, I lost a texture from a face in a 61k faces model. BTW what happens when you have coplaner faces with different textures, or images placed on textured faces (say a run on a wood floor). Didn't read all the post, so sorry if already covered.
                  At the moment it doesn't take into account materials. Only geometry.
                  Images? You mean an actual Image entity (It says "Image" in Entity Info when you select it?)
                    Well, I often import images (as images, not textures), and place them on textured faces.
                    They would be ignored.
                    However, I do plan on adding an option for it to respect the material of the geometry. Just got to sort out some other issue first.
                    • honoluludesktopH
                      honoluludesktop
                      • honoluludesktopH
                        honoluludesktop
                        Opps, added image after your post.
                          Seems another very useful plug β˜€
                          About the Ecuadorian file
                          Why not scale the file *10, apply the plug, then scale 1/10 ? πŸ˜‰
                            The scale isn't the issue.
                            • C
                              chango70
                              This works very well. I have made Ctrl Shift C short cut for it. Thank you!
                                @jim said:
                                Ack! it doesn't look at materials?
                                Oh, and thank you! πŸ‘
                                Option to respect materials applied added. On by default.
                                Ecuadorian:
                                I adjusted the tolerance so it shouldn't loose any geometry on the model you sent me. Hopefully it won't loose anything in other models either.
                                But there is some cases where which can be removed is left behind. I hope to address this. I figured it's best to be defensive than aggressive.
                                • E
                                  Ecuadorian
                                  Sounds nice, Thom!
                                  Perhaps you could give the user two or three threshold options.
                                  -Miguel Lescano
                                    @ecuadorian said:
                                    Sounds nice, Thom!
                                    I added an debug option which you can use for now. You can see it in the screenshot.
                                    The closer to 1.0 the stricter it is.
                                      @ecuadorian said:
                                      Sounds nice, Thom!
                                      As for the model you sent me, you won't have much luck reducing the tolerance because of the threshold where the edges can be removed overlaps. That model is a good example of a troublesome model - I'll try and get some Google heads to comment on what's going on.
                                      • I
                                        ideas_arte
                                        incredibly helpful, thank you very much πŸ˜„
                                        • N
                                          notareal
                                          πŸ‘
                                            Updated once again.
                                            Now has a dialog window where you can set various cleanup operation to be run on the entire model. Settings are persistent per session only.
                                            • 48
                                            • 49
                                            • 2 / 49
