    [Plugin] CleanUp
    974 Posts 217 Posters 967.0k Views 217 Watching
      SpookyChick1013
      Hi Thom.
      For the past month or so, I've been getting a funny error from your Cleanup plugin. I have weeded through my plugins since then and so far haven't been able to find any solutions.
      Anyway, here is the content of the error dialog:
      undefined method `purge_unused' for [:Array
      C:/PROGRA~1/Google/GOOGLE~3/Plugins/tt_cleanup.rb:1074:in remove_materials' C:/PROGRA~1/Google/GOOGLE~3/Plugins/tt_cleanup.rb:1037:in merge_similar_materials'
      C:/PROGRA~1/Google/GOOGLE~3/Plugins/tt_cleanup.rb:548:in cleanup!' C:/PROGRA~1/Google/GOOGLE~3/Plugins/tt_cleanup.rb:488:in show_cleanup_ui'
      C:/PROGRA~1/Google/GOOGLE~3/Plugins/tt_cleanup.rb:487:in call' C:/PROGRA~1/Google/GOOGLE~3/Plugins/TT_Lib2/inputbox.rb:161:in initialize'
      C:/PROGRA~1/Google/GOOGLE~3/Plugins/TT_Lib2/inputbox.rb:156:in call' C:/PROGRA~1/Google/GOOGLE~3/Plugins/TT_Lib2/inputbox.rb:144:in close'
      C:/PROGRA~1/Google/GOOGLE~3/Plugins/TT_Lib2/inputbox.rb:144:in initialize' C:/PROGRA~1/Google/GOOGLE~3/Plugins/TT_Lib2/inputbox.rb:132:in call']
      I have also checked to make sure I have this installed with the exact footprint you specified, and I do. I'm usually pretty careful about that, but at this point I'm double checking everything.
      Thanks,
      Cathryn
      https://kuromatsudriveyards.com
      Fo-su to tomo ni aran koto o...
        When do you get the error? When loading SketchUp? Opening the window? When starting the CleanUp?
        Does it happen in all models? What are the settings you run CleanUp with?
          bitslapped
          Hi thomthom I noticed you have a new 'merge identical materials' which seems like you had a crack at my request?! Thanks for that.
          I have been getting the same errors particularly when I run the cleanup with only 'merge identical materials' checked.
          The script still works for older functions.
          I'm running sketchup 8 and your latest libraries.
          Cheers
            Got a sample model?
              SpookyChick1013
              Sorry to take so long getting back here. Was out of town and off grid for a few days.
              Anyway, the errors only show up when I am actually running the script, after checking settings and clicking "CleanUp". I am using your latest library, and Sketchhup 7.1, as always. The error has occurred with every model to this point.
              The settings that I have observed the problem occurring with.  If I UN-check Merge Identical Materials, Cleanup works fine.
              Late Edit: Something bitslapped said got me thinking, and so I UNchecked "Merge Identical Materials". When I ran CleanUp with MergeIdenticalMaterials NOT checked, Cleanup ran fine; So I am wondering at this point if the problem is with that part of the plugin.
                driven
                hi Thomas,
                i'm getting path errors in safari
                Not allowed to load local resource:file:///Library/Application%20Support/Google%20SketchUp%208/SketchUp/Plugins/TT_Lib2/webdialog/css/ui.css
                note: I can run selection toy WD with it's path
                <script type="text/javascript" src="js/base.js"></script>
                I can't fathom your interface enough to switch paths...
                has anyone had it [cleanup3] all working on a mac? [I am using the dev version of safari]
                cheers
                john
                  I'll have a look next week. But are you sure you have the very latest CleanUp and TT_Lib?
                    @driven said:
                    hi Thomas,
                    cheers
                    john
                    I got a mac at home I test on - CleanUp should work.
                    ...what OSX version do you have?
                      Can you post a screenshot of this error? When does it appear?
                        driven
                        I'm still on 10.5.8, but safari 5.0.6 is the pre-release for the next safari and it stops Fredo's updater from checking here for updates, but I haven't had any local file errors from anything else, and sellectionToys works...
                        dev version of safari 5.0.6 is stricter
                        EDIT: checked on my macbook and it's OK for now...
                        The dev version of safari is a preview for safari 6, so soon everyone will have this issue...
                        is it possible to use the same paths as selection toys, because they work on both.
                        BTW... I modded the ui.css for nicer IMHO mac scrollbars
                        safari 5.0.3 on macbook OSX10.5.8
                        john
                          SpookyChick1013
                          Yeah. I wondered myself if I really had DL'ed and installed it, but I do have it. Freshly downloaded and installed, just to see if that would fix the problem. Seems to have cropped up since I originally updated to this latest version.
                            Driven: I have no idea why it says it is not allowed to load any local resource... I hope it's a bug in that beta version.
                            (btw - how did you edit the mac scrollbars? I thought only IE allowed that to be changed...)
                            Spooky & Driven: I won't be able to look into this until next week - when my vacation is over.
                              driven
                              just did some checking and it's not a bug or a beta,
                              it's now the current update with new security 'features'...
                              5.0.6 for Leopard or 5.1 for Snow and Lion,
                              anyone with auto update will already have this as well, there are no changes since the pre-release...
                              Webkit psuedo elements, here's a link with detailshttp://css-tricks.com/9130-custom-scrollbars-in-webkit/
                              I did a close[ish] match for Selection Toys
                              by dropping this into ui.css
                              ;;-webkit-scrollbar
                                  width; 12px;
                               ;;-webkit-scrollbar-thumb
                                  background; rgba(255, 255, 255, .25);
                                  border; solid 1px rgba(0, 0, 0, .25);
                              ;;-webkit-scrollbar-thumb;vertical,{
                              ;;-webkit-scrollbar-thumb;hover
                                 background-color; rgba(0, 255, 0, .25);
                              ;;-webkit-scrollbar-track-piece
                                  background; rgba(0, 0, 0, .05);
                                  border;none;
                                  border-left; solid 1px rgba(255, 255, 255, .1);
                              ;;-webkit-scrollbar-corner
                                  display; none;
                              for Cleanup I just dropped in the version I use as a Safari alternate CSS,
                              /* blendin mods */
                              ;;-webkit-scrollbar
                                  width; .5em;
                                  height; .5em;
                                  background;  transparent;
                                  -webkit-border-radius; 1em;
                                  border; solid 1px rgba(0, 0, 0, .05);
                                  background; -webkit-gradient(linear, left top, left bottom, from(rgba(255, 255, 255, .25)), to(rgba(0, 0, 0, .25)));
                              background-color; rgba(0, 255, 0, .5);
                              ;;-webkit-scrollbar-button;start;decrement, ;;-webkit-scrollbar-button;end;increment
                                  display; block;
                                  height; .5em;
                                  width; .5em;
                                  display; block;
                                  margin; .5em;
                                  display; none;
                              /* end of blendin mods */
                              you can set them here for Safari, WebDialogs need the css includedon all websites, iFrames can be flakey...
                              have a good vacation
                              john
                                Ah pooh! Cursed - now I got to dig into this new ... thing - whatever it is. Thanks for reporting though.
                                And thanks for the webkit CSS tip. 👍 👍
                                  Something's up with this .skp?
                                  uninitialized constant TT;;Sketchup
                                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;456;in `cleanup!'
                                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_cleanup.rb;442;in `show_cleanup_ui'
                                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;161;in `call'
                                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;161;in `initialize'
                                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;144;in `call'
                                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;144;in `close'
                                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/inputbox.rb;144;in `initialize'
                                  TT_CleanUp_Error.skp
                                    Actually getting this on any file?
                                      Yer CleanUp is out of date!
                                        Yer dead right 👍
                                        I'd forgotten I'd updated TT_Lib2 with Quad Tools. My bad.
                                          Ye!
                                          • W Offline
                                            wrc86
                                            http://img580.imageshack.us/img580/8752/capturadepantalla201108ft.th.png
                                            it's not working for me, it doesn't show any error when I start SU
                                            It just to work with my old OS, now I'm working with OS X LION
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 48
                                            • 49
                                            • 19 / 49
