    Notepad++ Ruby Syntax enhancement
    10 Posts 4 Posters 3.4k Views 4 Watching
    • thomthomT
      I use Notepad++ to write plugins. Great editor. But there's something with the ruby syntax highlighting that's always bothered me; inline if and unless statements isn't highlighted. Is there a way to configure the language to do so?
      I tried the User-Defined window to create a new Ruby style - but it didn't seem possible to set up the language to match the existing.
      • N
        NewOne
        πŸ˜„
        it doesn't highlight if it's placed after something... I think it's not recognized as expression
        • thomthomT
          Yes, but I'm wondering if it's possible to change the syntax highlighting so it does recognize it.
          • TIGT
            I also use Notepad++ and I just live with it...
            The Ruby Style would need to find not only '^if ' and ' if '... but also ' if*' or '* if ' or ')if ' or '^if(' or ' if(' or ')if(' etc whilst avoiding 'if' as in 'difference'... Perhaps a request to the author ?
            User defined language styles would mean you recreating ALL of the other Ruby stuff and THEN adding this !
            • thomthomT
              Is it possible at all to define that? I had a look at Format->User-Defined Dialouge... But I wasn't able to find such control. πŸ˜•
              • TIGT
                See this for help http://weblogs.asp.net/jgalloway/archive/2006/11/25/creating-a-user-defined-language-in-notepad.aspx
                • thomthomT
                  That's what I've been trying to use - but not been able to create the result I want. I even tried to open the XML file where it's defined, in-case I should find an alternative way.
                  Only other option I can find is writing a custom lexer - but that requires C knowledge - which I don't have....
                  • M
                    MartinRinehart
                    C isn't required. I've got lexers in Java, Perl and Python if you want to have a look.
                    Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
                    • thomthomT
                      Can a Python lexer work with NP++?
                      I've not used Java, Perl or Python - but I hear the leap from Ruby isn't that big. And in any case, the next V-Ray for Sketchup is written in Python so I will need to learn it anyway.
                      • M
                        MartinRinehart
                        I've no idea. Took a look. My lexer is a Decaf lexer, written in Python. Decaf (Java without the Jitters) is a beginners language I've designed and am working on, but not often enough.
                        Decaf is quite like Python in most things, except suites. I actually have decided to implement suites:
                        if condition
                            no braces
                            around this
                            block of code
                        # no braces, no begin/end
                        Fortunately for your requirement, Decaf's lexer still looks for {} around statement blocks.
                        Unfortunately, Ruby persuaded me to add trailing IF and UNLESS but they're not there yet, either. I could add those soon.
                        Here's the language description. Before you go here, "lexical analysis" and "lexing" are Decaf-described as "breaking the language into WORDS" (not tokens). Parsing is picking out PHRASES (not expressions) and SENTENCES (aka statements). The code and doc is in various stages of being converted to Decaf-speak.
                        # Decaf's EBNF grammar
                        # grammar of the grammar;
                        #     'x'     the character 'x'
                        #     'xxx'   the character string 'xxx' (as a separate word)
                        #     x | y   either x or y
                        #     [ x ]   0 or 1 x
                        #     x*      0 or more x
                        #     x+      1 or more x
                        #     {}      grouping, example;
                        #               "exp{',' exp}+" - "exp" followed by one or more "',' exp"
                        #     < xx >  comment (documentation of the grammar)
                        #     full_name, nm ;;=
                        #         x   'full_name' is defined as 'x', 'nm' is short for 'full_name'
                        #     xxx;    definition continued, next line
                        #     name ;;=
                        #         x
                        #         y   'name' is defined as 'x | y'
                        #     xxx_operator, xx ;;=
                        #           < operators of type 'xxx' listed here >
                        #---------------------- words -----------------------
                        constant_e, con_e ;;=
                            'E' = 2.71828182845904523536
                        constant_pi, con_pi ;;=
                            'PI' = 3.14159265358979323846
                        comment_eol_word, cmt_w ;;=
                            COMMENT_EOL
                        end_of_line_word, eol_w ;;=
                            END_OF_LINE
                        end_of_input_word, eoi_w ;;=
                            END_OF_INPUT
                        end_of_statement_word, eos_w ;;=
                            END_OF_STATEMENT
                        line_continuation_word, lcon_w ;;=
                            LINE_CONTINUATION
                        whitespace_word, white_w ;;=
                            WHITESPACE
                        constant_integer_word, con_i_w ;;=
                            CONSTANT_INTEGER
                        constant_decimal_word, con_d_w ;;=
                            CONSTANT_DECIMAL
                        lbrace_word, lbrace_w ;;=
                            LBRACE
                        lbracket_word, lbrkt_w ;;=
                            LBRACKET
                        lparen_word, lprn_w ;;=
                            LPAREN
                        malformed_number_word, m_num_w ;;=
                            MALFORMED_NUMBER
                        multiline_string_word, ml_str_w ;;=
                            MULTILINE_STRING
                        name_word, name_w ;;=
                            NAME
                        operator_word, op_w ;;=
                            OPERATOR
                        rbrace_word, rbrace_w ;;=
                            RBRACE
                        rbracket_word, rbrkt_w ;;=
                            RBRACKET
                        reserved_word_word, res_wrd_w ;;=
                            RESERVED_WORD
                        rparen_word, rprn_w ;;=
                            RPAREN
                        string_word, str_w ;;=
                            STRING
                        unclosed_multiline_string_word, unc_mls_w ;;=
                            UNCLOSED_MULTILINE_STRING
                        unclosed_string_word, unc_str_w ;;=
                            UNCLOSED_STRING
                        unknown_character_word, unk_chr_w ;;=
                            UNKNOWN_CHARACTER
                        #------------------- expressions --------------------
                        arithmetic_operator, arth_op_p ;;=
                        copula_operator, cop_op_p ;;=
                        comparison_operator, cmp_op_p ;;=
                            'GT' | 'GE' | 'EQ' | 'LE' | 'LT' | 'NE' | 'IN'
                        binary_logical_operator, log_op_p ;;=
                            'AND' | 'OR'
                        unary_logical_operator, not_op_p ;;=
                            'NOT'
                        other_operator, oth_op_p ;;=
                        expression, expr ;;=
                            arithmetic_expression
                            comparison_expression
                            logical_expression
                            parenthesized_expression
                            list_expression
                            range_expression
                            subscript_expression
                            function_call
                            selection_expression
                        arithmetic_expression, arth_exp ;;=
                            operand arithmetic_operator operand
                            '-' operand
                        comparison_expression, cmp_exp ;;=
                            operand comparison_operator operand
                        logical_expression, log_exp ;;=
                            operand binary_logical_operator operand
                            unary_logical_operator operand
                            'TRUE' | 'FALSE'
                        parenthesized_expression, paren_exp ;;=
                            '(' expression ')'
                        list_expression, lst_exp ;;=
                            expression {',' expression}+
                        range_expression, rng_exp ;;=
                            operand ';' [operand]
                            ';' operand < operands must be integers >
                        subscript_expression, sub_exp ;;=
                            '[' range_expression{',' range_expression}* ']'
                        function_call, func_exp ;;=
                            parenthesized_expression function_name
                        function_name, func_nm ;;=
                            NAME < name of defined or imported function >
                        selection_expression, sel_exp ;;=
                            NAME{'.' NAME}+
                        operand, oprand ;;=
                        	NAME
                        	constant
                        	expression
                        constant, cnstnt ;;=
                        	CONSTANT_INTEGER | CONSTANT_DECIMAL | STRING | MULTILINE_STRING
                        #-------------------------- other phrases ----------------------------
                        address, addr_p ;;=
                            PATHNAME < address on local machine >
                            URL < address on any machine >
                        capability_name, cp_nm_p ;;=
                            NAME < of capability type >
                        right_hand_side, rhs_p ;;=
                            rhs_qualifiers [type_name] variable_name
                        rhs_qualifiers, rhs_ql_p ;;=
                            [ 'LOCAL' | 'GLOBAL' ] [ 'RW' | 'RO' ] [range_expression]
                        return_types_list, rt_tps_p ;;=
                            type_name{, type_name}*
                        type_name, tp_nm_p ;;=
                            base_type
                            built_in_type
                            defined_type
                        base_type, bs_tp_p ;;=
                            'BIT' | 'BYTE' | 'CHAR' | 'DEC' | 'GROUP' |;
                            'INT' | 'NAMELIST' | 'TYPE' | 'SUB'
                        built_in_type, bi_tp_p ;;=
                            < see http://www.MartinRinehart.com/posters/decaf-object-library.html >
                        defined_type, def_tp_p ;;=
                            < types defined in page or imported from other pages >
                        variable_name, vr_nm_p ;;=
                            NAME < word, type==NAME, textValue contains name >
                        condition, cond_p ;;=
                            logical_expression
                        list_name, ls_nm_p ;;=
                            NAME < that identifies a list, array, NAMELIST or group >
                        self_name_p, self_p ;;=
                            'ME'
                        #--------------------- statements -----------------------
                        statement, smt ;;=
                            declaration_statement
                            action_statement
                        declaration_statement, dec_smt ;;=
                            var_declaration_statement
                            include_statement
                            type_declaration_statement
                            sub_declaration_statement
                        action_statement, act_smt ;;=
                            expression_statement
                            block_statement
                            if_statement
                            foreach_statement
                            while_statement
                            loop_statement
                            break_statement
                            return_statement
                        var_declaration_statement, vr_dec_smt ;;=
                            rhs_qualifiers type_name variable_name
                        include_statement, incl_smt ;;=
                            'INCLUDE' address {',' address}*
                        type_declaration_statement, tp_dec_smt ;;=
                            { 'CLASS' | 'CAPABILITY' } NAME1;
                                [ 'EXTENDS' NAME2 ];
                                ['CANDO' capability_name [, capability_name]* ];
                                [ MULTILINE_STRING ] < documentation >;
                                action_statement
                        sub_declaration_statement, sb_dec_smt ;;=
                            'SUB' '(' [ list_expression ] ')' NAME '(' [ return_types_list ] ')';
                        	action_statement
                        expression_statement, exp_smt ;;=
                            expression [ copula_operator right_hand_side{',' right_hand_side}* ]
                        block_statement, blk_smt ;;=
                            INDENT;
                                statement*;
                                UNINDENT
                        if_statement, if_smt ;;=
                            'IF' condition 'THEN' action_statement [ 'ELSE' action_statement ]
                        foreach_statement, for_smt ;;=
                            'FOR' 'EACH' variable_name IN list_name DO action_statement
                        while_statement, whl_smt ;;=
                            'WHILE' condition 'DO' action_statement
                        loop_statement, loop_smt ;;=
                            'LOOP'
                        break_statement, brk_smt ;;=
                            'BREAK'
                        return_statement, ret_smt ;;=
                            'RETURN' expression < expression may be expression_list >
                        #---------------------- program -----------------------
                        program, prgrm ;;=
                            statement*;
                            END_OF_INPUT
                        # end of decaf.bnf
                        This is drifting off-topic. Unless someone (anyone?) else is interested, maybe we could do this via Email. MartinRinehart at gmail dot com.
