    Method to identify what context the user is in?
    11 Posts 7 Posters 766 Views 7 Watching
    • F Offline
      fizgig
      When the user hasn't double-clicked on a group or component, the active context is the whole model (and the active coordinate system is the global coordinate system)
      If the user does double-click into a group, the active context is that group and the local coordinate system associated with that group.
      I'm trying to figure out how to tell where the user is when they start my script. I need to know if they aren't drilled down into a group or sub-group of a group or if they're all the way out.
      Does anyone know how to do this?
      • Chris FullmerC Offline
        active_path = Sketchup.active_model.active_path
        returns nil if they are not in a component. If they are inside a component, or drilled down a few levels, it will return each component they are within.
        Chris
        All my Plugins I've written
          Jim
          model.active_entities will return the entities of the editing context. Contrast to model.entities which will return all of the top-level entities.
          model.active_path will return an Array containing the sequence of entities the user has double-clicked on for editing. Or nil if none.
          Maybe one of those is what you need?
          • F Offline
            fizgig
            Thank you both very much. I believe that's exactly what I need.
            • F Offline
              fizgig
              In order to accomplish what I need, I use the info given above to get out of the context of the group back into the overall context:
              while !Sketchup.active_model.active_path.nil?
              	Sketchup.active_model.close_active
              It would be nice if I could save the position somehow, go to the global context as shown in the code but then go back to the context when I'm done. That way the user doesn't have to re-double-click back to where they were.
              I'm not seeing anything in the model class that would appear to do that. Anyone have any ideas?
                Why do you need to go out and back in the nested entities ? You can always get the user to pick something within a group (say), do things to it within it's entity set without having to open that entities set for editing ?
                  You sure you have to exit the current context, can't you take the model.edit_transform into account when doing your operations?
                  http://code.google.com/apis/sketchup/docs/ourdoc/model.html#edit_transform
                  • F Offline
                    fizgig
                    That was super helpful. I used that transformation matrix to adjust my data and it worked perfectly. Much obliged!
                      Jim
                      Could this be used to calculate scaled face areas in a Component?
                      reference: http://forums.sketchucation.com/viewtopic.php?f=180&t=16075
                        RickW
                        It was requested, but hasn't made an appearance yet. I reaffirmed the request.
                        RickW
                        [www.smustard.com](http://www.smustard.com)
                          leixing
                          [quote="fizgig"]
                          yes,I want this too.I ask the same qus here
                          http://forums.sketchucation.com/viewtopic.php?f=180&t=22915&p=193698#p193698
