    How to exactly scale a component to an absolute size?
    11 Posts 6 Posters 15.0k Views 6 Watching
      David.P
      Hi forum,
      I've downloaded a car model from the warehouse. So far, everything is fine.
      However, the car is not to scale. Therefore, I'd like to simply enter the correct length of the car while scaling it, in order to bring the car to scale.
      This however doesn't work because when scaling the car by it's length (pressing shift to constrain the car's proportions) it is not possible to enter the car's length into the Measurements box in the status bar -- because the Measurements box wouldn't accept any numbers when pressing shift at the same time.
      Also, it is not possible to attach a Dimension (from Tools -> Dimensions) to the bounding box of the car (as a component), in order to scale the car this way.
      Thus, I can see no single way to properly and exactly bring a component (here, the car) to an exact length.
      Thanks heaps already for help,
      Cheers David.P
      • X Offline
        xrok1
        draw a line on the ground beside your car, start inline with the farthest front or back extension of the car, then scale from the opposite end with shift and snap to the line. ๐Ÿค“
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
          d12dozr
          [flash=480,385:33vi5zbx]http://www.youtube.com/v/eXh6y5b0pdg&hl=en&fs=1&[/flash:33vi5zbx]
          http://goo.gl/f7ooYh
            When you scale you can type into the VCB the dimension you want.
            http://sketchup.google.com/support/bin/answer.py?answer=94906
            • X Offline
              xrok1
              very nice, thankyou Thomas. i had always tried this by just typing a number as usual and of course i assumed it did work because whatever i typed became the scaling factor. But DUH, if you add the " or ' it works. ๐Ÿ˜„ thanks for the revelation, sometimes we get so caught up in work arounds we forget work flow! ๐Ÿ˜†
                " for inches
                ' for feet
                But any metric unit such as mm, cm, m etc works as well.
                  David.P
                  Thanks lots guys.
                  Basically, xrok's advice was the way to go for me.
                  (As already pointed out above, typing the car's length into the VCB doesn't work in this case since you can't restrain the proportions by holding shift AND type in a number at the same time.)
                  Anyway, the 'snap to a guide line' did it.
                  Thanks again,
                  David.P
                  • jeff hammondJ Offline
                    jeff hammond
                    i like using the tape measure
                    it's probably covered in the video posted above but i don't feel like watching a 7min video right now..
                    to resize, you basically use the tape measure in the same way you use the line tool... with the line tool, after your second click, you can enter the length of desired line in the VCB and the line will be drawn to that length.. [the line shortens or extends depending on the value]
                    with the tape measure, after your second click, you enter a length in the vcb and the whole model is resized accordingly.. [the entire model scales to the length of your tape]..
                    dotdotdot
                    • X Offline
                      xrok1
                      well actually you could use the shift for proportion then click anyplace arbitrarily, then type the dimension. it doesn't matter if you've already clicked before you type a dim as long as you don't do anything else. ๐Ÿ˜‰
                        Hi David (and all who use feet and inches and need the Shift key to enrter a value),
                        Do somehow as Rocky says;
                        1. Start the scale operation (using the shift key if needed)
                        2. Release everything > Type the value (using the shift key if needed)
                        3. Hit Enter - SU will "remember" what it is supposed to do (in this case a uniform scale operation).
                          David.P
                          Thanks Rocky & Gaieus, amazing -- this of course did the trick even better.
                          Cheers David.P
