    [Plugin] Control points ver. 1.6.
    115 Posts 42 Posters 71.7k Views 42 Watching
    • K Offline
      kirill2008
      This plugin became obsolete but you can find all its functionality in 'Control Points' tool of 'LSS Toolbar 2.0' extension. It is still only a beta version, but this particular tool works stable enough. Find out more at http://sketchucation.com/forums/viewtopic.php?f=323&t=47399
      • E Offline
        Ecuadorian
        Wow, thank you!
        -Miguel Lescano
          Seems a cool one! 😎
            Just saw the video - very nice!
            Does it remember the control vertices across sessions?
              d12dozr
              Wow! Organic modeling just got easier Thanks, Krill!
              Is there a way to set each node's position on the curve manually, instead of just being evenly spaced?
              http://goo.gl/f7ooYh
              • P Offline
                pav_3j
                now this is very cool!
                thanks ever-so much!
                yay another toy to play with...
                pav
                Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                  Daniel S
                  Thank you Kirill!!!
                  Looks amazing!!
                  Daniel S
                  • K Offline
                    kirill2008
                    Unfortunately no 😕
                    I knew it would be one of the first questions 😄 , but it's not implemented yet. Actually I don't know yet how to make it... Maybe to launch a kind of entity scanner each time when new file loads. It will scan entities to link c-points to curve vertices again. But it will slow opening of huge models...
                    • K Offline
                      kirill2008
                      That's a cool idea 👍 I'll try to implement it. Current version does not allow manual node positionig.
                      • boofredlayB Offline
                        boofredlay
                        Wow, great stuff.
                        In your notes above you mention SU6. It seems to work fine in SU7.1 as well.
                        • mitcorbM Offline
                          mitcorb
                          Looks interesting, Kirill.
                          Will this technique do away with bezier curves?
                          What would be the difference in this and polylines?
                          EDIT!!! never mind my stupid questions. I had a good long look at the demo video.
                          Excellent work.
                          mitcorb
                            c.plassais
                            Excellent!!!
                              boofredlay
                              It might be nice also to have the undo function work for the whole action rather than each individual step in the script. For example I added 6 control points around a 24 segment circle and it took 50 undo clicks to get back to the creation of the circle, when all I did was run the script once. Make sense?
                              Not sure how to do this however, just a thought.
                              This one is going to be very useful for me indeed.
                              Thanks 👍
                                That's my concern for a plugin I'm working on as well... was curios to hear if there was any other way.
                                • olisheaO Offline
                                  olishea
                                  this is amazing
                                  thank you
                                  oli
                                  • EarthMoverE Offline
                                    EarthMover
                                    FANTASTICO!!!! Awesome Krill! I think an add control point tool would be a great improvement. Also maybe a simple option to add control points only to existing vertices. This would be great for a subdivided or tesselated mesh, but I think it would require an implementation of soft selection to make a further advancement towards organic modeling.
                                    Thanks again Krill.
                                    EDIT - DUH! I looked right past the option to add to "each vertex". Nevermind.
                                    I do vote for a Krill Toolbar though!!!
                                    Content Creator at Skapeup
                                    • utilerU Offline
                                      utiler
                                      Ditto, EarthMover!!! Toolbar for sure!!!!!
                                      Will somebody stop this guy............... 😮
                                      Just Curious...
                                        dedmin
                                        Да здравствует дружба между народами
                                        • wind-borneW Offline
                                          wind-borne
                                          Very interesting plugin.
                                          i am having a strange problem, plugin only shows up on initial opening drawing. If I open a new one without closing Sketchup completely, no plugin.
                                          I've tried copy from initial( where it works) and paste to new with real odd results also. The plugin then shows up but misbehaves. If I draw a new object, new construction points are put on the pasted object(even though I have deleted it) instead of new object which was selected.
                                          "To read between the lines was easier than to follow the text."OSX 10.11.6
                                          %(#BF80BF)[SU 8 pro
                                          • K Offline
                                            kirill2008
                                            As I can see on attached picture the whole face is selected, but current version of the script (ver. 1.1.) actually processes only curves. So try select only boundary curve without face itself (you may deselect face by pressing shift and single-clicking on face). Make sure that only boundary is selected. Of course script processing does not depend on opened file (old or new). It depends on what entity is the first one selected: if it occures that curve edge is the 1-st item of selected entities collection, then everything works, if the 1-st item is face, then the command does not appear within context menu.
                                            So I'll try to make the script more tolerant to the selection in future versions 😄 .
                                            Speaking of copy-paste behaviour, I'll try to find out why it processes so strange (don't know why yet).
                                            • 6
                                            • 1 / 6
