    Exporting from Sketchup
    11 Posts 4 Posters 945 Views 4 Watching
      Lee-Enfield
      hello, I am trying to export a 3D file from Sketchup 7 into chief architect 9.5
      but am having trouble finding out how to go about doing that....
        Depending of what formats is accepted by this prog?
        And if you have a free or Pro version of SU πŸ˜‰
          Lee-Enfield
          I am using the free versions of Sketchup..
          chief architect supports both .dwg and .dxf file types..
          • massimoM Offline
            massimo Moderator
            Hi Matthew, with SU free you can't export in those formats. Only with Pro version it's possible both in 2D and 3D.
              Jim
              The exporters are available for a limited time.
              Error 404 (Not Found)!!1
              (sketchup.google.com)
                Lee-Enfield
                ahhh yes ive just found that out..
                is there a way to convert a .skp file to a .dwg maybe?
                or a plug-in of some sort?
                • massimoM Offline
                  massimo Moderator
                  Hmmm, aren't them importers and not exporters, Jim?
                    Lee-Enfield
                    does that plugin both import AND export?
                    (i see someone already asked)
                      Jim
                      huh? what? I guess it is. 😳
                      But I thought there was a dxf exporter free somewhere...
                      Here is one: http://www.guitar-list.com/download-software/convert-sketchup-skp-files-dxf-or-stl
                      and one here:
                      http://www.ltplus-bau.de/download.htm#sketchup
                        Use the free Double CAd XT as go-between who allows you to load SKP files and export DWG or DXF (some versions so choose the year of your prog) πŸ˜‰
                        Does it not marvelous? 😎
                          Lee-Enfield
                          i think the doubleCad will work.................just as soon as i figure out how to use it πŸ˜„
                          thanks everyone for the feedback.
