Can be Imported a cad file with text?
Hi I would like to know if there is a way to import a cad file (dwg or Dxf) that contains important text?
SU will import only CAD geometry (and its hierarchy).
If you have AutoCAD you can explode the text into lines, then import that... BUT text is not importable - I have an embryonic tool to take the text out of a dxf file and then bring it into SUp with the text as my '2D Text' 'flat' text_like_compos... however, don't hold your breath - it's a looong way off...
@tig said:
What's the name of that tool?
When it is possible to write a small ruby to draw text in SU, then it should be a easy to make a autolisp-utility to write such ruby out from autocad.
I used such approach to restore block-infos on SU components which get lost during import.
@bravoddb said:
@tig said:
It's one of the Express Tools that ships with AutoCAD called ExplodeText - I think it's a lisp file...
@hpw said:
When it is possible to write a small ruby to draw text in SU, then it should be a easy to make an AutoLisp-utility to write such ruby out from AutoCAD.
It is indeed relatively easy for Ruby to parse the 'Text' data out of a DXF [then you won't need AutoLisp] and then to make bits of '2D Text' from it in your SKP... It's just having time to do write it that's the pain...
Register LoginAdvertisement
