    I have problems with rigth mouse button...Fixed!
    9 Posts 3 Posters 454 Views 3 Watching
    • N Offline
      nacholo
      Hello everyone.
      At first i am sorry at my english. It is really poor and bad. I try to use a traductor but.....
      I've been watching several times in the forum, learning from everyone.
      Now I have a problem and seeking help.
      The fact is that when I selected a component (It is highlighted in blue) and press the right mouse button .. for example to edit it, it is de-selected and i can not do the operation. This happens with everything I try to do in the picture with the "right mouse".
      In other programs the mouse works perfectly.
      I'm lost and I have no idea what it is.
      Thanks in advance for your help.
      Sketchup 6 pro Castilian, updated.
      S.O. windows xp date.
      Thanks and greetings
        Hi Nacholo,
        What happens if you go to Window > Preferences > OpenGL and disable either Fast feedback or Hardware acceleration? (Sorry, I don't know what they are in Spanish)
        • N Offline
          nacholo
          Thanks at your really fast reply!
          The harware aceleration and fast reply are ever disabled.
          do you another suggestion?
          PD:Dont worry at reply in english.I understand it better than write, usually.
            Well, in this case I don't have any other idea. Maybe just if you installed a driver for your mouse, there you could make sure it is set somehow that lets SU trigger the context menu instead of deselecting.
            • massimoM Offline
              massimo Moderator
              Maybe you just did right click outside your selected entities? In this case select your component (or group) then right click ON your selected entities and not outside.
                So how did you fix it?
                šŸ˜‰
                • N Offline
                  nacholo
                  Hello Gaieus:
                  I just solve it!
                  I am going to write it at here to help somebody in this problem.
                  The problem was produced by an obsolete ruby scrypt. It was "projections by Didier bur ver: 1.2 2005" When i dissable it all its rigth.
                  I am going to find the latest version and install it.
                  • N Offline
                    nacholo
                    Hello massimo:
                    Thanks at your reply.
                    The problem was when i click on selected entities.Really was a big problem. At the moment i fixed it.
                      Good - also thanks for the fix tip!
