    Vray shadow wont render
    renderpluginsextensions
    6 Posts 3 Posters 1.8k Views 3 Watching
      motley
      for some reason the shadow hittıng the chairs leg wont render. i have had this porblem with some other models as well. it renders if it is above the ground but not if it is touching it.
      http://img.photobucket.com/albums/v242/osman_naskali/PROBLEM.png
      • holmes1977H Offline
        holmes1977
        Cant really answer your problem but head over to http://forum.asgvis.com/index.php?action=forumwhere someone will.
        Exaggeration makes a dull story better.
          Seems to just be the angle of the sun that's pretty high up - so it doesn't cast a shadow very far. For your thin leg there isn't much to cast a shadow of.
          Adjust your sun to be slightly lower and see then.
          What V-Ray for Sketchup version do you use btw?
            motley
            the shadow length should be about twice the actual length. so i should be able to see some thing.
            thanks holms, ill give them a try.
              What version do you use?
                motley
                sketchup 7.0 with the first version of vray 1.5 i dont think it was ever updated.
