    SU 7.1 Shadows drop between scenes
    6 Posts 2 Posters 605 Views 2 Watching
      Charlie__V
      First,
      Very pleased with the performance increase...especially with a old 108mb file I tested and SU 7.1 behaved quite nicely.
      Also very pleased to see dimensioning in LO.
      So my Q,
      I am experiencing shadows dropping out between scenes, and immediately if I orbit the model or initiate any other command.
      This is fine and I can get used to this.[the drop of shadows on orbit I mean]
      More clearly, I have 2 identical scenes except for the time of day, when I toggle from first scene,say 8:00 am to 2nd scene, say 4:30pm the shadows go away untill the transition is complete.
      IOW, no active shadow study while transitioning between scenes.
      I have exported to avi and the shadows do present in all frames of a video.
      My hardware maybe?
      Specs:
      Dell
      XPS M1730, Intel Core 2 Extreme X9000(2.8GHz, 800Mhz 6M L2 Cache)
      NVIDIA SLI Dual GeForce 8700MGT with 512MB GDDR3
      4GB, DDR2, 667MHz
      320GB 7200RPM Hard Drive
      OS: XP Pro SP3
      Anyone else experience this.
      FYI I have fussed with open GL settings etc with no change.
      Best,
      C
        remus
        Its done on purpose to speed up the rendering of your model. SU drops certain elements then redraws them when you dont move the display for a set period of time.
          remus
          Another thought: if you dont want it to do that, try putting this Sketchup.full_detail_render_delay_min=0.0 in to the ruby console. Havent tested it, but it should work.
            Charlie__V
            Remus,
            Thanks for the quick reply, I am not surprised by your answer, just hoping to have all the cake....... :~)
            The script I will try for my machine, but was hoping to send a very simple shadow study to a client.
            Unless that will go with the file? [I am significantly Ruby challenged, among other things]
            Thanks lots,
            C
              remus
              unfortunately i think that setting is only persistent on your machine and isnt transferable with the model. If your client hasnt upgraded though you may still be in luck.
                Charlie__V
                Remus,
                Ruby line you graciously wrote did not seem to work.
                Though I did say I am Ruby challenged,
                I pasted the code in the ruby console and hit enter, it appears as I believe it should without errors.
                Though I notice no change in the model scene transitions.
                It's ok, I'll just work it out with an AVI, or if with the client just use SU V6.
                EDIT:
                I can of course just use the shadow slider & or instruct the client to do the same.
                Thanks so much,
                Best,
                C
