    [Plugin] FreeDXF Importer
    148 Posts 41 Posters 197.5k Views 41 Watching
      Jim
      Updated to version 0.9.0 with support for SPLINE entities thanks to rsa.
      Splines are added to the model as Bezier curve objects, and are editable through the right-click menu.
      Update available through the SketchUcation Plugin Store.
        tweyermann2
        THANK YOU SO MUCH!! I HAVEN'T BEEN ABLE TO FIND A PLUGIN THAT WORKS SINCE SKETCHUP 2015 REMOVED DXF SUPPORT FOR THE FREE VERSION. THANK YOU!!!!!!! πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
        • W Offline
          wootton
          Does version 0.9.0 work with SketchUp 2015 free version? I'm currently using v0.8.2 with SketchUp 2014 (works great, thanks!)
          Tom Wootton
            Jim
            Yeah, 0.9.0 works on 2015 Make.
              abbis
              Hi All,
              Can anyone please assist. I am working on a MAC, (OS X 10.8.5), I have Sketchup Make 2014 installed, and I have installed the FreeDXF v0.11.1
              I am trying to import the attached .dxf file. (which is an export from a GIS program). The file opens easily in CAD lt2011 as well as in vector programs such as Illustrator.
              When I first attempted to import the file nothing happened in sketchp. With the ruby console open I get the following error:
              Error: #<Errno::ENOENT: No such file or directory - /volumes/projects/x training/buildinglines_saveas.dxf>
              /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/dxf2ruby.rb:54:in initialize' /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/dxf2ruby.rb:54:in open'
              /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/dxf2ruby.rb:54:in parse' /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:252:in import'
              /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:219:in do_import' /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:112:in block in do_options'
              /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:82:in call' /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:82:in block in trigger_event'
              /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:78:in each' /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:78:in trigger_event'
              /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/SKUI/window.rb:357:in event_control_callback' /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/SKUI/window.rb:311:in callback_handler'
              /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/SKUI/window.rb:269:in block in add_callback' -e:1:in call'
              Can anyone help?
              Many thanks!
              dxf file I have attemped to import
                Jim
                Is your filesystem set to case-sensitive?
                Either way, try version 0.11.2 I just uploaded to the PluginStore.
                  driven
                  @abbis said:
                  Error: #<Errno::ENOENT: No such file or directory - /volumes/projects/x training/buildinglines_saveas.dxf>...
                  copy the file to your Desktop rather than using a mounted volume...
                  also, do you have TeighaFileConverter.app installed?
                  Jim, the new versions working well on my mac...
                  john
                    Jim
                    Thank you for verifying, John.
                      abbis
                      Ah!
                      Thank you very much John! The mounted volume seems to have been the issue. I can import the file fine now. Thanks Jim, I will install the 0.11.2 and give that a try shortly.
                        mgate
                        First of all, thanks a lot for your plugin, Jim.
                        Just a query about the Teihga converter.
                        The dwg import option doesn't work (with SKU 2015 Make and latest FreeDXF v.0.11.2).
                        The Teigha has been installed in the default folder, and works fine. However, in SKU when I try to import a dwg file, that format is not available in the dialog box (only the "Cad files" option for dxf files), as if the plugin doesn't grab the converter.
                        Does anyone solved the same issue?
                        Many thanks in advance for your help.
                          driven
                          are you importing from the Extensions or File menu item ?
                          john
                            mgate
                            john
                            through the Extensions (the dwg format is not available in FreeDXF Importer plugin)
                            I looked into the Ruby file "teigha.rb". Is it required an additional file or library called "fileutils"? If so, that file is missing inside "jf-freedxf" folder.
                            require "fileutils"
                            module JF
                              module FreeDXF
                                module Teigha
                                  # Teigha Command Line Format is;
                                  #   Quoted Input Folder
                                  #   Quoted Output Folder
                                  #   Output_version {"ACAD9","ACAD10","ACAD12", "ACAD13","ACAD14", "ACAD2000","ACAD2004", "ACAD2007","ACAD2010"}
                                  #   Output File type {"DWG","DXF","DXB"}
                                  #   Recurse Input Folder {"0","1"}
                                  #   Audit each file {"0","1"}
                                  #   [optional] Input file filter (default;"*.DWG;*.DXF") (Use File.basename(filename))
                                   if Sketchup.platform == ;platform_win
                                      EXE = "C;/Program Files (x86)/ODA/Teigha File Converter 4.01.0/TeighaFileConverter.exe"
                                   else
                                      EXE = "/Applications/TeighaFileConverter.app/Contents/MacOS/TeighaFileConverter"
                            In my WIN 8.1 Pro, the Teigha sofware is installed in the default folder too:
                            Cheers!
                            • hdpvH Offline
                              hdpv
                              I have some update!
                              Suforyou
                              http://www.sketchupforyou.com
                                driven
                                @mgate said:
                                through the Extensions (the dwg format is not available in FreeDXF Importer plugin)[
                                You can select a .dwg or a .dxf file and it should import...
                                that's in the SU Ruby folder, so it's already available from there...
                                have you tried it with 'Ruby Console' open to see if there are any error messages?
                                the other thing to try is doing the conversion directly in TeighaFileConverter, if it fails there you may get a reason given...
                                john
                                  Jim
                                  Actually, I don't think fileutils is needed. I think I was going to use some methods in fileutils to search for the Teigha converter on the disk drive, but haven't got back to it.
                                  You can remove or comment out the line.
                                    mgate
                                    neither working if commented out the "fileutils" line.
                                    I have a folder with two files in dxf and dwg formats:
                                    snapshot of folder with dwg and dxf files
                                    Once opened the "FreeDXF v.0.11.2" pop-up window, there is only the dxf file (the dwg file is not available):
                                    snapshot of FreeDXF pop-up window
                                    Is there a problem with "extra extensions"?
                                    def self.select_file(extra_extensions = "")
                                          title     = 'FreeDXF Select DXF File'
                                          directory = nil
                                          # filename  = 'DXF|*.dxf|DWG|*.dwg||'
                                          filenames = "Cad Files|*.dxf" + extra_extensions + "||"
                                          file_path = UI.openpanel(title, directory, filenames)
                                          if file_path.nil?
                                            return nil
                                          else
                                            file_path.tr!('\\', '/')
                                            @last_selected_file = file_path
                                            return file_path
                                        def self.main
                                           puts "\nFreeDXF debugging ON." if $JFDEBUG
                                           extra_extensions = Teigha.available? ? ";*.dwg" ; ""
                                           file_path = select_file(extra_extensions)
                                           return if file_path.nil?
                                           #file_path.downcase!
                                           if file_path.end_with?(".dwg")
                                              Teigha.dialog()
                                              file_path = Teigha.convert(file_path)
                                              if file_path.nil?
                                                 puts "dxf file was not created."
                                                 return
                                    Any idea how to solve?
                                    Another way is to convert dwg files manually with TeighaFileConverter, and then use FreeDXF plugin in SKU.
                                    Sorry to snoop around your codes 😐
                                      Jim
                                      This appears to be due to a difference between SketchUp 15 and SketchUp 16 UI.openpanel behavior.
                                      As a short-term work-around, can you try to enter a * then press ENTER in the filename dropdown to force all files to be listed?
                                      • atelierpaarA Offline
                                        atelierpaar
                                        Hello Jim
                                        A couple of days ago I posted a request for a plugin that would import measurements directly from a 3D Laser "Leica Disto S910 " in order to draw direct on site.
                                        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=64830%26amp;p=594596#p594596
                                        Could your plugin be developed to do the Job ?
                                        Thanks for your response
                                        Uli
                                        • K Offline
                                          Kuu
                                          Nice plugin, works much better than the SketchupPro import. However, there's a few things I've noticed:
                                          β€’ It does not respect blocks' scaling / orientation properly: blocks that were mirrored in the original DXF sometimes end up in strange positions (this does not happen with the other import).
                                          β€’ Perhaps related to the last issue, sometimes I saw blocks that had the proper orientation but had ellipse elements that were rotated in 90 or 180 degrees.
                                          β€’ Layer colors? Why doesn't it keep the DXF layer colors the way the sketchup-included DXF importer does? Currently I work around this by importing it with one (to get the layer colors) and then delete all the geometry/components and reimport with yours, would be awesome to not have to do this.
                                          β€’ It would be nice if the import also preserved layer visibility, or have a toggle to choose on import. Currently it sets all the layers to visible.
                                          β€’ Another toggle to merge DXF layer 0 to sketchup's Layer0 would be handy too.
                                          β€’ Is it possible for it to keep polylines? I don't know if it's a DXF limitation or Sketchup or what. Polylines would be a godsend!
                                          I'm on SketchUp 2016 and macOS 10.11.6 in case that's relevant...
                                            Jim
                                            @kuu said:
                                            Nice plugin, works much better than the SketchupPro import. However, there's a few things I've noticed: ...
                                            Hi Kuu, thanks for the feedback.
                                            Could you provide a minimal .dxf example file, and example result?
                                            Maybe related, maybe not - ellipses have proven difficult to crack but it's been awhile since I've had a look at it. Again, a minimal sample file demonstrating an incorrect ellipse would be helpful.
                                            Layer colors? Visibility?
                                            I wrote this long before SketchUp had support for setting layer colors. Now it does. Can have a look.
                                            • 6
                                            • 7
                                            • 8
                                            • 6 / 8
