    Moving objects in space
    8 Posts 5 Posters 1.5k Views 5 Watching
    • A
      Antonino Giglio
      Dear friend,
      I've drawn a couple of objects using sketchup but i'm stuck.
      I didn't understand how to really move the objects in space. I know how to attach one object to another using 2 points but I still cannot properly move an object in space.
      In fact I always endup putting the object I'm moving on a wrong plane.
      For example I tried to place some small plants on the top of a structure I built but I can't manage to stick the plants in the right position, they always end up far from the object or inside it.
      I know it is easy when you have 2 points but what about if you have a flat surface and no near angles?
      Any video tutorials around to understand this issue?
      Thank you so much!
      “Passion and enthusiasm are fed by the Dream of bringing Green back into our cities to make them finally livable, collaborating and not fighting with Nature” http://vision4ourcities.com/
      • D
        d12dozr
        Its all about learning how to use the "Inferencing Engine"...or maybe just draw a temporary line to where you need your plant at, move it there, and delete the line 😉
        Good tutorial here:
        http://www.youtube.com/watch?v=aGVUI2AeMOc
        More of them here:
        http://www.youtube.com/results?search_query=sketchup+inferencing&search_type=&aq=0&oq=sketchup+infere
        http://goo.gl/f7ooYh
        • A
          Antonino Giglio
          Good tutorial here:
          More of them here:
          Thank you very much for the help!!!!!! 👍 😄
          • denbostD
            denbost
            What d12dozr said about using inferences is your best bet im sure, but if its not, this program might be able to help you too.
            http://www.renderplus.com/wk/RpTools_w.htm
            "Design is a plan for arranging elements in such a way as best to accomplish a particular purpose."
            Charles Eames
            • A
              Antonino Giglio
              Ohhh thank you very much! But I use Mac and this plugin looks like it is only for Windows. 😞
              • GaieusG
                Have a look at Jim's "Mover" plugin then; I'm pretty sure he makes his plugins cross platform:
                http://sketchuptips.blogspot.com/2007/08/plugin-mover-2.html
                • M
                  MartinRinehart
                  Before you move, Tape out guides. Moving to the intersection of guides is easy and dependable.
                  Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
                  • GaieusG
                    Yes indeeed - and I haven't even used any of these plugins. One somehow "knows" where to move (snap to) and that's the best way to get used to SU in general, too.
